Scrap Corian
Bruce, a MN Galoot
and other solid surface leftovers. Does anyone have any idea what to do with it? I've got a bunch of pieces big enough for cutting boards, etc., mostly ivory and white.
Scrap Corian
Bruce, a MN Galoot
table saw inserts
Re: Scrap Corian
Walt
I used little bits for band saw blade guides. I haven't used 'em much yet to see how they wear (or don't).
Re: Scrap Corian
Charles Yawn
Scrollsawers like it to cut various patterns. I would be interested in some of the white and colored sheets if it can be mailed reasonably. I am used to 1/2" but could work with other thicknesses.
Charles Yawn
Re: Scrap Corian
Grant in Iowa
Some wood turners like the stuff for inlay work. You might ask at a local club.
Regards,
Grant in Iowa
Re: Scrap Corian
John Veerkamp
Can be worked with regular wood working tools. glues up with epoxy. I've seen almost anything that is segmented including turnings, chess boards, cutting boards etc.
Re: Scrap Corian
Bruce, a MN Galoot
I turned a couple small bowls a few years back. That was the messiest turning I've ever produced.
Re: table saw inserts
Bruce, a MN Galoot
Good idea. Corian also works pretty well as a strop, used with green or gold compound or AOx powder, too.
Re: Scrap Corian
Paul Blackwell
I made serving trays out of the sink cutouts. Cut in handles on the ends and routed a groove around the perimeter. I epoxyed small pieces on the bottom to make it easier to pick up.
Re: Scrap Corian
kruizen
I mounted a piece to face plate for the lathe, turned the face flat, Now I have a sanding disk on lathe, WORKS GREAT!!
Re: Scrap Corian
Jim Hoeller
I used kitchen sink cutouts to make window sills in my new house. Two part epoxy and a good clean joint made the seams almost invisible.
