200+ woodworking book reviews
scale model
scale model
scale model
Robin Corell
It's been a while since I've posted here, mostly because I've been working mostly with steel and bronze lately. I'm starting a new commission and thought I'd post a photo of the model. I will be starting a blog on my web page to document the progress for the client and with Ellis's permission Ill post here as I make updates for those that might be interested. I am hoping to do a couple of videos along the way.
The top will be a slab of claro walnut with live edges, the leg with curves will be carved monterey cypress and the other leg will be welded steel. The stretcher will be a combination of wood and steel.
[URL=http://s453.photobucket.com/user/rcorell/media/furniture/Albrect%20table%20design%203__zpsvkxb3tac.png.html][/URL]
Re: scale model
Re: scale model
Bruce Mack
Have you other idea for the stretcher? I think it is a weak element of the design. Perhaps something angular like a steel triangle would better complement the rippled leg.
Re: scale model
Welcome back
Nice to see you again, Robin. Feel free to post your updates here. I for one appreciate mixed media pieces. Steel, stone and other materials are all fair game for furniture design. Wood is only part of the picture.
Nifty looking design. Thanks for the preview.
Re: scale model
Re: scale model
Robin Corell
Here is another picture that kind of shows the stretcher from a better angle. As it is in the model it definitely has issues. As pictured I think it is it is way too big and clunky. Right now I am leaning towards making the long curved part tapered so that it is much smaller where it joins the yoke part, which I am visualizing as being in stainless steel and much more delicate. I want it to have an elegance to it like a marine fitting from a vintage Americas cup boat. My hope is that by having the angular leg being the only hard edged component and with a nearly black patina that it will serve as a visual anchor and make the other parts seem more dynamic. I talked with my client at the presentation about these changes and they are very open to me making any other changes I feel are necessary.
The other change I would like to make I may not be able to . I would like the table to be at least another foot longer. I am hoping that when the client comes over to choose from one of the four slabs in that flitch that they will want to use more than 6 feet from the 10 foot long slabs. It has a space it has to fit in so that change may not be possible.
Re: scale model
Re: Welcome back
Robin Corell
Thanks Ellis. Thirty years ago I did mostly mixed media work. It feels good to get back to that again and I fell lucky to have a client that is open to the idea of a sculpture with table on top of it.
Re: scale model
Weight
Robin,
Both views you've provided show the steel element that, to my design sense, is too dominating in visual weight. With this as a 6' table, the actual weight of that element will also be very substantial. The contrast between the organic lines in the wood elements and the hard geometry, crystalline form of the steel section could be accomplished with less weight.
Am I correct to assume that the steel will be left as "metal" rather than pigment-coated? Painting it would tend to defeat the purpose of the material choice.
Don't forget to post an image of the final piece.
Re: scale model
Re: scale model
Bruce Mack
I just checked your website, Robin, and suggest that others do so. The furniture is beautiful in proportion and color. No doubt your table will be stunning. Thank you.
Re: scale model
Re: Weight
Robin Corell
I'm definitely pushing it in regards to balance with this design. I agree with your opinion that painting a steel component would negate it as a material choice. I've been experimenting with patinas on steel lately and have developed some very interesting finishes. you can see some examples of these finishes on instagram where I post as robincorellart. For this project the steel will be dark with some grey and gold tones in a mottled pattern. And you are correct that it is a large geometric shape, the only geometric shape in a curvilinear design. I am hoping that by making it so dark that it recedes a bit with the lighter colored more dynamic shapes working together to balance against it. The client has given me free rein to make any changes as I see fit and I'm just stupid enough to cut something apart so I can shave a 1/2" off to make it "just right".
As far as physical weight the steel leg a rough calculation puts it at 97lbs. Once I pull more exact measurements off my model and decide on the internal structure I can get a more accurate calculation but the rough number tells me that it won't be too overwhelming. My concern was working on it in my shop.
Re: scale model
Re: scale model
Robin Corell
thanks for the kind words about my work.
