Krenov style cabinet construction?
Denny
I'm starting on a walnut Krenov-style cabinet, about 22" x 28". Normally when I'm building case pieces, if I can bend a board into place by hand I don't worry about machining it perfectly flat. I'd like to take the same approach with this cabinet because I'd rather not lose any thickness. Am I likely to run into trouble (mostly with fitting doors, I assume)? I'm thinking the cabinet will glue up square and present no problems. Any thoughts or wild guesses will be appreciated.
Thanks,
Denny
Re: Krenov style cabinet construction?
Solid
joinery can hold a case square, but doors have to be flat, flat, flat
Re: Solid
Denny
Thanks, that's what I was thinking.
It
do, of course, depend of the kind of wood, how thick, and how "winded" the board is. Personally, I would look to get "flat" pieces as flat and straight as possible. A piece much out of true gets returned to the bin to be recut on another project where the recutting can eliminate most of the "defect".
It's wood.
It grows on trees.
Work with it, not against it.
Re: Solid
TomD
And ideally the doors need to be quarter sawn, or you need some other reason to believe they will stay put. The house I live in was owned by a cabinetmaker. He made a number of krenov like cabinets, but he used lumber yard flat sawn for many of the door frames and they have twisted badly in some case. The wormanship was excellent, other than that.
Krenov engineering
Without being more specific it is impossible to answer your question. Where is this "bent" board going to be used and how much is it "bent"?
I have built two Krenov cabinets and I would not have been successful without some guidance from a Krenov student. Someone needs to do a book on Krenov engineering, that is to say his techniques for assembling these things. They are not obvious, yet essential to achieving a structurally sound piece in his style. After building one I became impressed that Krenov was a skilled engineer to figure out how to make what he envisioned.
To give one example, the sides are dovetailed into the top and bottom. There is a jig for aligning the holes to a precise fit. But why use such an inferior joint and not mortise and tenon? The door is made first and the cabinet fit to the door. The case will be dry fit, disassembled, adjusted and reassembled countless times to get the fit and reveals perfect. M&T would be toast by the end of it all (been there and done that on round 1). But only two dowels are used for dry fitting. When all is well they are tossed and the full complement installed. The tight fitting plywood back is glued in place to provide structural rigidity.
These cabinets are small and their looks depend on accurate fits and reveals. The joinery is not such that components can be forced into some configuration against the boards wishes.....if that helps
And, when building a $1000 cabinet don't get cheap selecting the $50 worth of wood.
Jesse Cloud
If you are using the standard Krenov joinery, a line of dowels, holding the sides to the top and bottom - that joinery will straighten out a small bow, but it will be the devil to bend the board to fit the dowels.
If you are not particular about the flatness of the sides, then I would suggest using a cutoff from end (which will have the bow) to make doweling jigs with. Just leave the side long, drill the dowel holes, cut off some for a jig, use the jig to drill the corresponding holes in the top/bottom.
Having said all this, if I did that - if would probably be cursing myself for not just getting the thing flat in the first place. Or using a different joinery.
Thanks folks, you convinced me...
Denny
I dug around in the wood pile and found some flat stock that will certainly work.
I'm using an excellent article by Jim Budlong from Fine Woodworking Nov/Dec 2009 as a guide. He spent 14 years working with Krenov, and I've been successful following his approach before.
Thanks!
Denny
TomD
"If you are using the standard Krenov joinery, a line of dowels, holding the sides to the top and bottom - that joinery will straighten out a small bow, but it will be the devil to bend the board to fit the dowels."
And often a major challenge is laying out (and in the case of dovetails cutting the joint) in the round, for later assembly in the flat.
Re: Krenov engineering
TomD
"I have built two Krenov cabinets and I would not have been successful without some guidance from a Krenov student. Someone needs to do a book on Krenov engineering, that is to say his techniques for assembling these things. They are not obvious, yet essential to achieving a structurally sound piece in his style. After building one I became impressed that Krenov was a skilled engineer to figure out how to make what he envisioned."
I doubt that, and I don't know what these complexities are, plus his books detail his methods at till the mid-70s. :) I would welcome a more modern book.
"To give one example, the sides are dovetailed into the top and bottom."
Dowelled right?
"There is a jig for aligning the holes to a precise fit. But why use such an inferior joint and not mortise and tenon?"
Of course today one could leap ahead and use Dominos. Well people with the machines could. I think one of his students Janofsky might have used tenons, though I also think he used dowels.
I think Krenov used dowels mainly because it is in the European tradition to do so, and because the scantlings he used were very heavy and would easily hold his projects together. I have seen chairs where the frame or legs were held with a couple of small dowels, huge loads, and I know this because they eventually failed. But he is using a ton of beefy dowels, on a project that is barely loaded at all. Also, they just had their own way of doing things. I called the College of the Redwoods when the plane video cam out, and asked them why they pared the dowels on the crosspiece, rather than use a lathe, and why they drilled the cheeks on a horizontal drill machine rather than a drill press. And they just said it was better practice that way, which has some truth to it if you like practicing bad techniques, and not learning good ones. But that isn't to say they were wrong.
" The door is made first and the cabinet fit to the door. The case will be dry fit, disassembled, adjusted and reassembled countless times to get the fit and reveals perfect. M&T would be toast by the end of it all (been there and done that on round 1). But only two dowels are used for dry fitting. When all is well they are tossed and the full complement installed."
Good point. Pretty basic stuff. I learned the hard way to figure what parts where the variable, and to build around them. I have built several tables where I made the base first according to plan, then foung the top was not coming together to size. If I have really nice boards for the top I will do what is right for them not worry about the exact dimensions, but if the base is made first (makes a good place to build the top), it can get hairy.
"The tight fitting plywood back is glued in place to provide structural rigidity."
Never saw him use a plywood back, but then the books stopped coming out about 45 years ago. He used to use a frame and panel, and had distinctive ways of cutting the edge treatments and raising the panel.
TomD
Is that your cabinet Bill, you really got close, it is beautiful. Did you try glass shelves?
