Plugging Router Table Hole
Doug Reynolds
I want to mount a router lift in my existing router table but the current hole is larger than the lift's plate. Is there a way I can plug the existing hole and cut a new one? I know I can make a whole new top and that is my backup plan but, was hoping to re-purpose the existing one. An internet search does not show anyone making blank tops. My router table has the router off center so, all the new ones with the hole in the middle will not work. I was thinking of template routing but have not done that before. TIA, Doug
Re: Plugging Router Table Hole
TomD
A picture might help or a link to the same tool.
Sounds similar to the process of making a table saw insert, basic woodworking. If you are asking about the actual hole the router projects through, and it's attachment holes, can't you use the existing insert as a guide to route those in or spot holes on the drill press? You could use a trim bit to transfer the main hole.
TomD
In specific cases it can be a mater of what tools you have and are comfortable with. I have made this kind of thing on the lathe, or made templates for them on the lathe. If there are ledges for interlocks or collets, they can sometimes be milled with rebate type bits, or cut with hand tools such as those used to bind guitars. Once we know what the part needs to look like, it is on to figuring out the option with the tools that you have that create the greatest certainty of result if that is what you are after.
Dick Coers
You could make an adapter ring that fits the table hole and then has the internal hole dimensions for the lift plate. Or you could move the plate to one side of the existing hole, then you only have two boards to cut to fill in the space. You can run cleats across the hole to carry the adapters and router lift plate.
Doug Reynolds
Sorry, I was not more clear. I have a JoinTech router table top with a hole for a larger router table base plate than the JessEm router lift I am installing. The hole needs to be just a little bit smaller. JoinTech is out of business so, I cannot buy another top from them. The top has all the accessory mounting holes I use so, I am avoiding making a new one and starting all over again. May have to anyway if there is no good way to plug the existing hole.
Frame it in
Hi Doug,
If I understand you correctly, I'd make a wooden frame, routed out to fit your JessEm, and accurately rabbet it into the existing top. It would really be a simple router-template procedure.
Not sure how else to do it.
That's what I tried to say
Dick Coers
So we either need some dimensions and/or pictures to help.
ChuckInND
Doug, How much larger is the hole in the table top then the new base plate ? Have you ever lived in Vancouver, Washington ?
Doug Reynolds
The existing hole is less than one inch all around too big for the new lift. I think the rabbeted picture frame is the way to go with some two-part epoxy for glue and, if needed, some metal plates underneath for strength.
I live in a suburb of Seattle, Auburn, and never lived in either Vancouver.
ChuckInND
Your probably right about going with the rabbeted picture frame technique. I was just wondering if you were from Vancouver because I use to live there back in my high school days and our neighbor across the street their name was Reynolds. They had two boys about my age, one had a roofing business and I worked for him for one summer. But now that I think about it, the boys names were Rick and Mike, no Doug. But who knows, maybe a relation of yours.
Doug Reynolds
I opted for a new top of 3/4" phenolic covered plywood after an attempt at framing in the old one.
