ADVERTISE HERE - FREE TRIAL
2 Makita chuck problems
Keith Newton
I've got several 18V Li-ion drills and impact drivers, and have chuck issues with both types.
The drill first, is a LXFD01. The jaws will only close down to about 5/16". I thought I would take the chuck off, but broke the screw driver blade trying. I've also sprayed it full of WD40, then run it in and out through the range of motion it still has, to no avail. Any suggestions?
The impact driver is BTD 42. It has a bit stuck in it that I can't change. Usually when I find one of these gets stuck, after heavy use driving clockwise, I just hit reverse for a short burst under load, and they usually release. But this one isn't turning loose for anything. I've lubed, tapped in and out, forward and reverse, but nothing seems to release it.
Re: 2 Makita chuck problems
Jack Guzman from Maine
I had a problem with bit holders getting stuck all the time in my impact driver. I found out that the bit holders I was using were of a soft metal(cheap)and were deforming under impact. I started using a better quality holder and haven't had one get stuck since. With bits that stick hard sometimes a sharp rap with a metal hammer directly on the tip of the bit frees it up.---Jack
Thanks, I finally got it.
Keith Newton
I didn't think we had a makita repair place here anymore, but I was wrong.
I had tried tapping in on the impact driver, and did again, with no results. But then before heading to the repair place with both, I finally found my small 12 oz hammer, and managed to hold back the release ring with one hand, and gave it a quick tap with the claw outward on the bit. Luckily it came out.
They replaced the chuck on the drill for $55, so now they are both back in service.
