Storing Wood
Stuart Johnson
Is it better to store dried wood horizontal or standing on end. I have 12' walls so height is not problem. It seems standing up would be easier for selecting.
Storing Wood
Stuart Johnson
Re: Storing Wood
I have read pros and cons for both. I have 100's of BF of 4/4 - 8/4 cherry and other boards standing on end since it takes less space, I don't have to build racks, and as you mention, it is easier to look through them.
OTOH I have had 3/4" pine from the borg become bowed from leaning against the wall.
Re: Storing Wood
Jack Guzman from Maine
In one of his books I remember James Krenov selecting wood for one of his projects from a group of vertically stored boards.
I expect it doesn't matter,as long as the floor doesn't contain moisture that could affect the ends.---Jack
Re: Storing Wood
del schisler
i have stood my wood on ends for yrs and never had a board go bad in any way's , i put a board flat than stand wood up on the board as straight as i can , also yrs ago i hung lot's of wide and long board's from my old bldg, and that worked out ok too good luck
Re: Storing Wood
Walt
It seems like vertical with a support or two in the middle to prevent bowing would be a good way to go. Storing horizontally the board you want is ALWAYS on the bottom.
Storage theory
So long as the lumber is not pushed into some shape it doesn't want to be it will stay the shape it is at. Hardwood is stiff enough that it is unlikely to flex if stored vertical. However, if one were to lean a pile of 6' pieces against a 16' piece, the shorter pieces could bend the long piece and over time the bend would set permanently.
Same principal for horizontal storage. If the rack was not straight the lumber stored on the bowed rack would eventually acquire a bow.
Re: Storing Wood
John McGaw
If vertical clearance was no problem I'd go for vertical every time. The more vertical and less lean the better of course, to reduce possibility of inducing bowing. Some sort of retention mechanism, even a stout rope would be good insurance in case the earth moves or somebody makes a bonehead move as would a platform to keep the bottom ends away from the floor a bit. I'm forced into horizontal storage, Lee Valley galvanized rack components which are great, but it will never be easy to pick out wood stored this way. I just discovered some really fine tiger maple which has been lost in the rack for at least twelve years.
Re: Storage theory
TomD
Periodically one sees that poor piece of wood that gets caught between two fork lift pallet batten sets, and the end result looks like a sine wave. I always want to ask about getting that one piece of wood, just to see the look.
