Flattening a winded board.....
Somewhere along the way I learned to called a twisted board "winded".
Been trying to prep some cherry for the beds I am making. These boards are about 66" long and 6" wide and 1" thick. Cut them to length and laid them on a flat surface. One corner at one end was about an 1/8" off the table. The opposite corner at the other end was about the same. I used my taper jig and ripped two slivers that tapered from an 1/8" to nothing about two feet long. Glued them to the board with Cyno. Ran them through my lunch box planer with the wedges on the bottom. It knocked the high corners off and flattened the top. Turned it over and planed the other side after removing the wedges.
Seemed to work well. I have used the jointer for this, but this seemed easier. I have hand planed one side, but again, this seemed easier. Any thoughts?
