Performax 16/32 drive belt problem
john Lucas
I know we've been there before but that was over 2 years ago before I had to move and put things in storage. I'm back to that problem. I've done a lot of repair of machines and you tension the side you want the belts to track towards. I've tried and it doesn't work. I found this in their manual.
If there is drifting, tighten the take-up
screw nut (Figure 22) on the side toward which
the belt is drifting, and loosen the take-up screw
nut on the opposite side.
This is an older machine. Could bearings on the rollers cause this. I did a lot or research on the web and this is a common problem. There is a belt that some swear by. Here is the link.
http://accuramachinetools.com/replacement-conveyor-belt-for-accuraryobiperformax-etc-1632-sa.html
Re: Performax 16/32 drive belt problem
I have that same machine. I bought a replacement belt at WoodCraft. I installed it and it runs a little too close to the motor side, but I left it alone. As I recall, the belt adjustment is counter intuitive. The belt runs "uphill". Lengthen the bed on the side you want the belt to move to. I believe that means you loosen the bolts. fine adjustments moved the belt radically.
I am going to have to do it again. The join is failing on my belt.
john Lucas
loosening the bolt on mine means that side would have less tension. I'll try to get out there tomorrow and play. right now I'm exhausted. I've split wood for 2 days and have a pile as big as my SUV. Now it all has to be moved by wheelbarrow behind the sheds.
Too Much Tension
Barry, if your belt is separating, you need to back it off a bit. I had that same issue with my 22-44 Pro. Went through a couple of belts until a local shop owner told me to bake off the belt tension. You play a game trying to get enough tension to drive the wood through the sander (and not stall) while not so much that you overcome the belt's joint glue.
With lesser drive tension you have to take lighter cuts on the abrasive, but that seems to help the drum stay cleaner with less heat build.
They make a black rubber/urethane drive belt for my machine but the price was just not worth it. My current drive belt has been on the machine for close to three years and doing fine.
Mark mentioned tension on the belt
Dick Coers
Try to tighten one side just a little, and an equal loosening adjustment on the other side. Also, you have to be patient. Just a small adjustment and let it run for a while. When I first got one, I made way too much of an adjustment, and chased it for quite a while. I don't think rubber would work well at all. Get a layer of dust on it and it would loose traction really quickly.
Re: Mark mentioned tension on the belt
john Lucas
Dick I've loosened and tightened both sides and let it run until it almost rubs the side. It tracks the same direction all the time. I think this morning I'm going to try putting layers of duct tape on the adjustable roller to build up a crown in the center. One response I saw when I googled this problem suggested that worked. Nothing else I've tried so far works.
I'm going to try flipping the belt which is a pain in the but and most posters who tried that it didn't help. Still it seems like that could be the problem although I think I did that a year ago when trying to solve this problem. Of course it then tracks to the right instead of to the left I would still have to try the crowned roller solution.
Ken Krawford
John I recently went through problems getting a new belt to track on my 16/32. Here's what I learned:
Several calls to Jet always started with the same question - what brand belt are you using? I'd struck out on 2 different (non-OEM brand) belts. This time I got the 3M brand belt that Jet sells specifically for this sander. It is much thinner with a finer grit than the others I tried. It tracked much better than the other belts initially but slowly had a tendency to drift right.
The instructions in the manual for adjusting the tracking are wrong and need to be reversed. The belt must be LOOSENED on the side it it drifting towards and TIGHTENED on the side where you want the belt to move to.
Now everything is tracking perfectly.
Some success
John C Lucas
Cleaned and lubed all the bronz bushings. Then i flipped the belt and plahed with the adjustments. The adjusters sure dont seem to do much. Anyway i got it close enough that we leveled and sanded a 32"x60"x 1 1/2" counter top and onlh had to stop once to ßlide the belt over. I measured the gap between the belt tightening brackets with a dial caliper so i could loosen them, slide the belt and then tighten them to the exact same setting
Re: Some success
I have a Performax 22-44 and had the same problem. I think I discovered the same thing as Ken and had to adjust the opposite way as described in the manual. I remember it was a pain. I can check my notes when I get back to the shop.
