building a curved handicap ramp
john Lucas
My Dad is finally coming home from an extended hospital stay. He will be in a wheel chair when he's not sleeping. The problem is going to be getting him to doctors appointments. I may have to build a curved handicap ramp to go from the front porch out the existing sidewalk. It's a 3 step rise and the sidewalk slopes down.
Any ideas on how to build a curved ramp. I just started looking up specs. My family may have other ideas when I get down there next week but I thought I would start the ball rolling and gather ideas. The only other option would be to put an elevator in the stairs going down to the garage. However that's pretty expensive and unfortunately we think he won't be around very long.
Re: building a curved handicap ramp
C. John Hebert
Instead of all that...why not just build an elevator using a 1 ton winch? I live on the second level and built a dumb waiter used to hoist up firewood every day, as well as groceries and if I'm ever unable to use the stairs for myself at some point. The winch can haul 400lbs no sweat and hasn't failed yet in 13 yrs as it travels in any kind of cold or wet weather, over 8'. The winch cost less than 120.00, and a sheet of plywood and a few scrap pieces of plywood for a box and 2 4x4's with a dado for a track to accommodate hardwood guides screwed to the box sides.
Do look into the specs for the ramp. IIRC the slope should be less than 1 in 12, with a level landing about every 12 feet. So if those thee steps total to about 24" them the ramp will have to be about 24 feet long with a landing making it even longer. As far as the curve goes, that would be interesting. How about a right angle turn? Much easier.
A guy who shares the office I'm in sells stair lifts. The chairs that ride up and down stairs. That might be an option. Used ones might be available. Sadly, some people don't live long enough to wear them out.
Another thought. The third guy in the office buys stuff at freight auctions and other places and resells it on E-bay, Craig's list, and where ever. Recently he has come into about three Wheel-O-vators. These are lifts designed to lift a person in a Wheelchair. Had one that would go 8' and another that woudl go 5', both sold. I think there is a third one coming. This could be either indoors or out doors. They have all the safety interlocks built into them. If the third one is still available, I could check on the price and range of movement. Obviously, it would be used and I have not seen it to comment on condition or price.
Easy but work
Having done curved walkways for our house
the process is not difficult but is a lot of work.
For true curves you'll need 1/2" PT ply cut to 12" width and something to soak the planks in. You then lay out your curve an put in guide posts. You make your joists out of the ply, 4 layers thick, bent around the guides with each layer stagger-lapped and glued (PL-4000 etc) and screwed into the previous one as you work around the curve
You'll need three joists supported/fixed with posts to the ground, and then top it with 2x4 or 2x6 treated that you cut with a taper jig, then trim off the outside and inside curve with a jig saw.
Second way is to lay out 2x10 joists in sections to make 22.5 or 45° bends then do the 2x top with tapers to make up the angles.
Laying your 2x decking (round-over router the top edges) cross-wise insures good traction for feet and wheels and drainage.
Couple More
Framing:
Roughed decking before the clean-up cuts:
Re: Couple More
john Lucas
I thought about bendable ply but wouldn't you need it to be outdoor grade or possibly water resistant or something similar.
Pressure Treated
1/2" ply is available in 4x8 sheets. Soaked well you can easily bend to make a 8' radius curve. Using the PL-#### glue and 1" screws while wet it will set up to very strong joists in place and no, you don't need to score one side of the ply to get it to bend when wet. There is, of course, a limit to the radius before the ply will fracture, but likely you won't want a sharp curve for the chair anyway.
You haven't shown a site plan so I can't tell what your space tolerances will be. You'll also need to determine what your total drop. Could be you'll need to do a "Disney" ramp with 1 or 2 switchbacks instead of a continuous curve
You can get pressure treated ply
Keith Newton
You make no mention of the radius. If you take a long thin batten, you can bend it in place to help visualize the path out in space, as well as use it to mark the perimeter once you build it.
Keep in mind that through tight bends, the inside stringer drops at a steeper pitch than the outside, which means you will need to be able to twist any sheet material deck.
If you go with solid treated lumber, the best way Ive found to eliminate a lot of waste in cutting tapper, is to start with wider lumber, like 2x10". If you need a 36" path, you might need 40" lengths, so cutting 3 out of 10' or 120". After they are cut to length, mark the center both length and width. Lay one in place, then lay a straight edge on top, and mark a radius to the curve. You can set up a stake or target to aim the straight edge at each time, which takes the guess work out of estimating the radius.
When you cut the line, flip the other half, and the tapper of it will match what was just cut, with no waste. Plus, the thin end will be wide enough to have enough strength to do the job. Whereas if you start out with say 6" wide lumber, you will end up with a lot of long wedges of waste.
Wider & Waste
In doing the sunrise deck pictured, I used 8' 2x6 and cut two out of each board with very little waste for the outside curve cuttings. Tapers ran from about 1" to about 3-1/2" adjusted slightly to fit to my try-line radius gauge. The decking is screwed down with no gaps with #10 stainless and the 1" points were fixed with #7 trim-heads. They have held up just fine for 20 years so far, although we power wash and re-seal every 2 years. Traction paint would be even better for a handicap ramp.
Bill Turpin in WNC mountains
Don't forget that a curved ramp will need to be wider than a standard code ramp. Not knowing your fathers condition, figure the true turning radius of the chair with leg lifts raised and extended. Use properly coated thru bolts, and hardware to fasten cross members, etc to posts. Do not depend on screws only at that point. Use screws to hold things down not to support weight. Balusters must be spaced according to code, Plan on almost 50% shrinkage of balusters for safe and legal spacing! Decks that I built twelve years ago needed 4" spacing, I installed them at a shy 3.5", they are now 5"! Have fun John, you probably will not be able to use your lathe on this project! I always use 2X material for deck surface, I do not depend on 5/4" prettified boards for the surface. The deck I built in 1983 is still going strong. Remember that the ramp might be used by someone else after your father has passed.
why not use a landing?
Grant in Iowa
Lucas,
Difficult to picture your situation, but I am having trouble understanding why a solution with a landing won't work. Use the landing to make whatever turn need be made, and it is a spot to rest for the person doing the driving. Indeed, ADA requires landings here and there anyway.
I would just build a landing square with the house door, and an edge aligned with the sidewalk. Easy cheesy.
Another thing to think of is the threshold in to the house. Consider a zero clearance threshold in to the home. You might think it would be easy enough to pull a wheelchair bound person up a few inches, and that may be correct. However, a strong person isn't always available, AND it can be scary riding in a wheel chair being lifted.
You should know that I have been through this very situation. I too built an ADA ramp, and by the time I got it done, mom lived there only another week or two. Everyone's situation is different, and I don't claim to know yours. That said, if I had it to do over, I would buy one of the pre-made metal solutions, and sell it after it is no longer needed for similar money. I would have been much better off spending the time with mom. Global industrial has several solutions that may help your situation.
FWIW,
Grant in Iowa
Brad Chenoweth
John,
Is you Dad a veteran? If so, the VA often provides assistance with this kind of thing. They recently installed a wheelchair lift for a friend of ours who suffered a stroke. The local veteran's affairs office should be able to provide answers. Just a thought.
Brad Chenoweth
john Lucas
Thanks for the responses so far. I'll know more when I get back home on the 27th. Now that I think about it the first 8 feet or so I believe is straight so I could go from the porch out to a flat landing and then start the curve. I'll have to check it out when I get there. Thanks for the advice.
Rise/run issue with curved ramp
Pete in Holland MI
If you're gonna stick to the 1:12 rise/run ratio, there is a problem with a curved ramp.
The inside radius will have a quicker rise over the run than will be the outer radius. The wheelchair will most likely not "flow" around the corner.
Pete
Re: Rise/run issue with curved ramp
John C Lucas
Hell this is NASCAR country im going to build in a banked corner .
Yeeeee-Haw!
