Delta 28-180 bandsaw question
Dan Bundy
Had to get replacement tires for my tabletop 8" delta bandsaw. The old tires were black and rubbery and had a bit of a crown to them. The new tires (from e-replacement parts) are yellow and more "Plasticy" (urethane?). The also appear to be flat on one side and a little bit concave on the other. Will it matter which side is out when they are stretched onto the wheel?
I know BS tires have some crown, so this threw me. I've had the saw for well over 10 years, but this is the first time the tires needed to be replaced. Thanks for any advice.
Re: Delta 28-180 bandsaw question
del schisler
i belive you will be ok , just set the top wheel so that the band runs in the middle of the tire and do a reset of the guides and thrust beiring , and do a blade drift while you are at it , if you don't know about that post back i have done a few tire changes on different saws also good luck
Re: Thanks!
