type wood to match with macassar ebony
ebd
ebd
I have a nice board of macassar ebony that is 4" wide - enough for the sides of a box but not wide enough for the top and bottom. I've been going crazy trying to find a type of high quality wood that would match well with the macassar.
I have a really black piece of african blackwood that would be great but it's turning stock - maybe 2"x2"x12". I can't figure how to join ¼" thick pieces side by side and have any structural strength.
I looked over what is available locally and no joy. I'd order from West Penn but it seems they have a 10 BF minimum. I really hate spending a lot of money for "sight unseen".
Any suggestions would be appreciated. Oh, and I won't color, ebonize, etc. The only finish I will use on this project is buffed oil.
Thanks fo any help.
Re: type wood to match with macassar ebony
Rick W
You can indeed join the 1/4" pieces of Blackwood together and have plenty of strength.Luthiers join thin wood together all the time for stringed instruments.
Just be sure your edges are well-jointed. I'd use epoxy with light pressure to glue them together.
Rick W
The look of macassar ebony
Chuck Nickerson
is all over the place. Any chance you could post a photo?
Width of top and bottom?
If you post the dimensions you're looking for, maybe someone could supply you with Macassar ebony of that size. Would veneer work?
Ellis Walentine, Host
Hank Knight
I wouldn't try to match the ebony. I'd look for something lighter in color/tone that harmonizes with the ebony. Most macassar ebony is streaked with lighter brown to honey tones. Pick something close to that and the dark ebony will be a striking contrast.
ebd
ebd
Thanks guys. I figured out what I'm going to do. For strength I'm going to resaw at about 5/16" and use a simple lap joint and do the join. Once glued up I'l run it through the planer to take it down to ¼" I'll use a piece of the Macasser for the center and use the African blackwood on each side. I'll post a picture once I get it done (if I like it).
