Simple way to even out color on Walnut?
tom
Have a project , an interior sliding "barn"door made out of walnut. The walnut has a variety of color. So yesterday I did a sample with some Bartley Gel Stain. Seemed to even the color out . The client is coming to the shop this Am to see if he would like the "natural" or the evened out look.
Any other suggestions?
Re: Simple way to even out color on Walnut?
I've used NGR dye [TransTint in alcohol] stain to do this. The dye won't build in the grain and it's easy to apply extra to light (sap-wood) areas and control how much to apply without killing the grain figure. Attached is walnut side-boy finished in poly and rubbed out to serious gloss
tom
What color dye?
TransTint
Dark Walnut #6005
[direct from Homestead Finishing]
Re: TransTint
tom
Mark, Forgot to ask. Did you spray it? Also I am fortunate I live about 45 minutes from Homestead!
Experience factor
It is easy to use gel stain if the piece is sanded perfectly. It takes some experience to spray NGR stain to achieve the desired result.
when you speak of color differences are you speaking of sapwood-heartwood differences or heartwood differences? The heartwood will even out just through light exposure.
Personally I stain all the walnut I use with burnt umber pigment stain, but to get a uniform result the piece needs to be sanded perfectly.
Application
I have sprayed dye but you need a small gun with very good control. The side boy was hand applied with gloves and a fine sponge so its was easier to "track" the line between white sap and heart wood. Need to be careful not to rub second or third coats as they will redissolve the prior. The sponge let me "dab" it on. You'll want a clean rag to feather the edges of the application area to erase any laps, and you can blend areas with a rag moistened with dna after the dye has all dried.
Of course, if you have an air brush, you're golden. I have a CA Tech Jr. mini-gun that will operate at very low pressure with a narrow cone and the material dialed back. Not as fine as an air brush, but good enough for what I do.
Re: Experience factor
tom
Well the fellow just came and saw the door. He decided he did not want "color" but really wanted the natural variations.
Thanks for your help. Though I may fuss with some scraps for my own edification!
Jesse Cloud
Another strategy is to start with an NGR Yellow stain, which will lighten the dark parts and darken the white parts. Then seal, then apply brown and/or red stains to get the color you want.
When you are experimenting, use scrap pieces and write on the back of each piece what you did to it. Otherwise, all the tests kind of blur together and you can forget which is which. DAMHIKT ;)
