I'm a fairly new 'woodworker' and I have a question for everyone. Can you give me some suggestions for clean-up, especially after using finishings (all types). What do you all do with the used rags? Do you end up throwing them away? Do you actually wash them and reuse them? If so, how do you wash them? How about brushes? Do you reuse containers?
I realize it really depends on the finish-type used but I'm open to suggestions for all types. A very much 'Thank You' a head of time for your advice and your time!
Water base rags - throw them away. Oil base rags - dry them thoroughly, laid out flat on concrete or steel, away from any combustibles, then throw them away. They are just rags, and are consumables.
Cheapo $2-$3 brushes with water base - rinse them in soap/water, or just water, and use them again unless finish has hardened, in which case, throw them away. Cheapo brushes in oil base - throw them away, particularly if the solvent costs more than the brushes are worth.
Quality brushes, either oil or water base, rinse them thoroughly in the proper solvent, form them back to original shape if possible, making sure they are DRY, and use them for a long, long time.
I can't stress enough, though, that ANY rag used with an oil base finish should NEVER be tossed into a trash pile unless completely dry! Spontaneous combustion is a serious concern with damp oil base finish rags.
Not an expert, but this works for me.
p.s. Foam brushes are great for some things, but they tend to cause small bubbles in some final finishes. Great for stain or paint, not so great for poly, varnish, etc....at least in my experience.
I don't use rags. There are a variety of paper shop towels - I use Scott "Rags in a Box" - 200 towels in a box - lint free. You can see what you can find elsewhere - but there are others.
Like Joe said, I let them dry and throw them away.
Brushes - for oil based finishes or stain I buy boxes of inexpensive Chinese bristle brushes that come in a number of sizes. I choose an appropriate size for the project. I have the option of cleaning them or not as I choose. As I burn my scraps and yard waste, it is nice to have something to use as a starter.
Water based - I have my good brushes and my not as good brushes. I clean those until they are too worn to use.
Containers? I am not sure what you mean. I put finish in jars - but that is because I "blend" my own finish (mineral spirits, polyurethane and boiled linseed oil or tung oil). I reuse the jars until they are too beat up to use. As far as the original containers that contain stain or finish? They get left open to dry completely and then thrown away. The cans of solvent have their tops removed and then get recycled.
Lots of good advice. As you get more involved you will find what works for you. Chinese bristle brushes will drop bristles one at a time EVERY time they are used. As such they are used on "not so critical" projects like sanding sealer, first coats. dust removal. They are disposable no matter the finish once dry. Harbor freight sells boxes of 1",2", and 3" quantity 36 at a reasonable cost. If you do need to extend time to use them though wrap in saran (to help hold the shape) or other plastic wrap put that into a freezer bag and put them in the refrigerator until you get to a second coat the next day or later in the same day.
Rollers I have cleaned and reused, but they seem never to do the job they did when new. I have wrapped and saved rollers many times, but almost always for paint, not clear finishes. They last one project, and get tossed. I like the nylon short nap applicators for flat surfaces, but they too get tossed when done and dry.
Containers for me are mostly glass wide top jars. Mix what I need and toss when finished. the one exception is some laboratory "plastic" (Nalgene) jars I found that are impervious to acids and most solvents. These do get cleaned, reused and stored. Paint is almost always poured from the can to a second container.
Rags are a different story for me. I have shop towels (paper), rags and good rags. Favorites on the good end are cotton t shirts and "hospital" sheets that have been washed dozens of times. I often get t-shirts from church sales and wash them 3-4 times before even considering them for use. These are finish rags and I try to care for them, but once used for any finish and they dry even slightly, when I'm done they get laid out and tossed when fully dry. These are also the gotos for mirrors, lenses, and polished surfaces. As has been stated with solvent at $17 gallon and cheap brushes at .50 it makes economic sense to toss much of finishing materials.
If you do however have some exceptional good brushes some of my favorites are the older PPG "Gold Stripe" brushes, they are babied to the point of obsession. When you find a really good brush, you'll know it. There are more bristles, they are feathered, and finishes just flow. They get cleand and again with brush cleaner, shaped and hung in open air.
Get yourself a box of 100 disposable nitrile or latex (if you're not alergic to latex) examination gloves and wear them when you're fooling with finishes and solvents. You get very good tactile response from nitrile or latex and they sure make cieaning your hands easy after a finishing session. Moreover, solvents take away the natural oils in your skin and will wreck your hands after a short while. A box of 100 gloves will last a fairly long time. I usually get two or three wearings from a pair before they puncture or split. Then just toss tgem in the trash and get new ones out of the box.
Hank has also made a good suggestion. I would only add get your disposable gloves from a paint store instead of a big box - they are slightly thicker and less likely to tear as you are putting them on.
They certainly are made to dispose of, but the work better if they are cleaned and reused. They drop hair, but it stops dropping shortly, and after that they are fine. I keep them in a jar of whatever solvent. Mostly I use them with epoxy, I cut them off below the holes, scratch them on cement until they have rounded edges allowing them to fit in small coffee cans, then I used them, wipe off excess epoxy, drop into acetone jar, doesn't take much acetone. I can keep the same brush going the whole summer season. Usually I am forgetful and have to throw a few out.
If you're working with solvents the nitrile gloves will keep the nastiness from being absorbed through the skin. A little solvent on the skin won't kill you right away, but overtime you can do some damage.
