Coping saws - push or pull?
Tim Greif - West of Chicago
Years ago when I first learned about coping molding on inside corners, I was taught to install the blade with the teeth facing back toward my hand and to pull the saw through the material. I've done that for years. I recently saw an article that recommended installing the blade facing forward, just like a conventional hand saw. That would require you to push the saw into the cut. Just sort of seems unnatural to me to do it that way. Just curious. How does everyone else cope? Push or pull?
Re: Coping saws - push or pull?
Pull
I prefer.....
Brian Roberts
....when actually doing crown molding coping....to push the saw.
Works better for my sawing hand motion....and the ability to see the cut. The work piece is supported on the bench/sawhorse and the cut pushes it to the support rather than pulling it away.
Try it...
For other types of cuts I prefer to cut on the pull....when cutting inlay pieces over a "bird's mouth" for example.
Jason Roehl in Lafayette, IN
Pull...for the same reason
I hold the workpiece on the bench (or miter saw, which is usually the case), as close to the cut as I can, and pull-cut with the handle below the workpiece, and the blade vertical.
Great visibility and the handle is out of the way.
Jason
Back angle.....
Brian Roberts
When I am coping the back angle is drastic....so the handle is well off to the side.....very hard to get that angle with the handle underneath.
There is no need to be more vertical with the cut....hence the more pronounced angle.
Once I was taught to increase the back angle and cut on the push stroke my copes became much quicker......and fit the first time......usually.
Both, actually
Rick W
I was always taught to install the blade with the teeth facing the handle, as the OP said.
However, when I started coping base and other moldings when trimming out houses, I was taught to have the teeth facing forward, so the saw cuts on the push stroke. That works well, and it makes it easier to follow the line when coping.
I still use a coping saw that cuts on the pull stroke for contour sawing and clearing the waste between dovetails.
Rick W
You need a good stiff one on the push stroke
Keith Newton
All of the frames are not equal, and some are too limber, which causes them to flex, then the blade pops off. Ha, I'll bet you thought I was going to talk dirty didn't you?
If you have a lot of copping to do, you might google for some videos showing how to use a an angle grinder.
Pull stroke and 1" caulking
