I would go to someone with a wide belt! *LINK*
Grant in Iowa
If I had to sand a house full of base and case (and I have done it), I would absolutely load it all up and go to a shop with a widebelt sander.
And that is coming from someone with a Supermax 25" sander that works great.
Here's why I take that position. Firstly, any drum sander only contacts the work piece in one area. Better production wide belts route the belt around a platen, which makes for a larger contact patch with the work piece. This results in an easier path to a flat surface free from uneven waves. These waves can creep in to work run through a drum sander without proper support, skill, paper, and a good bit of patience. Sure, you can do it, but it is tedious and time consuming.
Secondly, even if one has a very nice drum sander (and I think I have one of the best available), one probably doesn't have the in-feed and out-feed support setup to allow long stock to feed through smoothly, let alone the space needed for 14' stock. Keep in mind that most drum sanders, the Delta notwithstanding, adjust the feed table, not the drum. So each pass can require changes to the in-feed and out-feed setup for best results.
Thirdly, an industrial duty wide-belt will hold the work piece more firmly using its in-feed and out-feed rollers. In contrast, heavy consumer grade drum sanders all seem to have underwhelming feed roller setups.
Fourth, and perhaps the most significant is TIME. If you are trimming out a home, you are either building your own, or you are trying to earn money on someone else's dream. Either way, you are probably needing to save time where possible for other more productive efforts. When we built our home, we sanded and finished all of the trim work for a 3200 square foot home with Craftsman influenced styling. I didn't have the drum sander at the time, and we ended up using high end hand sanders (Fein) for the majority of the finish sanding. One thing I was very short on during the build of our home was TIME. I lost lots of sleep for a week or more of sanding. I dreamed of a nice drum sander at the time. Now that I have one, I understand its limits and the fact that, while faster and better for parts it can support easily, it is hard to use with long stock such as trim components. It excels on work pieces shorter than about 7-8 feet in length, but the fiddly nature of adjusting support rollers constantly means it is not an ideal tool for long parts.
So, knowing what I know now, I would take the job to the right tool, which is a wide belt sander of the industrial variety.
I will go on by saying that I will not sell my drum sander, as it has allowed me to make incredible parts from figured woods that I would otherwise not be able to flatten in the home shop. It also saves loads of time flattening and smoothing panels when doing casework. Want to do a production run of cutting boards? There is no better way to flatten and sand them than a drum sander (except a $20,000 wide belt).
Regards,
Grant in Iowa
Supermax pro 25
