Need Some Math Help With Air Flow
John Foster
Hello All
I have brushed on this topic with previous questions regarding cutting window openings in exterior doors at a building supply store. We stock exterior solid slab metal clad doors, and cut in the inserts according to customer needs. To try to control dust, we have a plunge style circular saw on order which will be connected to a dust extractor. We will have a new table with downdraft suction to grab dust from the underside of the door. Our stock doors are pre hung, so the door frame supports the slab above the table, and also creates an enclosed space under the door.
My question is regarding hole size and quantity in the table top. we are going to use the blower unit from a King KC-4045C dust collector (3hp) . The standard window insert size is 22" x 36' . My first thought is to make a series of holes in the tabletop below the perimeter of the cut for the window insert (about 116" of perimeter) with some sort of boxed in raceway under the table below the holes, which the dust blower will be connected to. Can anyone tell me a size of hole and spacing? What about the raceway below the table, what size should it be, should I make it in more than one section, or draw air from more than one point?
Thanks for the help.
John
