I'm making drawers out of (flatsawn) maple sides and back. I'm half-blind dovetailing to the drawer fronts. I'd like to use quartersawn oak as the drawer front. But the maple will expand more than the quartersawn oak. I calculated up to a 1/32" difference over the 7" width of the drawer front. Should I abort and use flatsawn oak? I don't want my dovetail pins to crack.
I probably wouldn't worry about it, for one thing the fronts will get a lot more exposure to the elements than the sides. It depends on where you live; where you might move; and how you keep your house; and what kind drawer you are making, in some cases you might have seasonal problems with those drawer sides; how tall the drawers are, the relative thickness of the parts...
I'm not sure what it would take for this to happen.
Will this piece live in a controlled atmosphere, or do you live somewhere that requires no heater or AC? If it is going to live in a controlled atmosphere, and your wood starts out around 6-8% MC, then it shouldn't experience any change, unless your plumbing breaks while you are off on vacation.
Also, since dovetails are such a good mechanical joint, there isn't much stress on glue joints.
The fronts will experience more change than the sides, since they are enclosed inside the carcass, with their own mini-atmosphere, so I would say going with the QS would be the best choice.
