The Real Problem
is "Cross-contamination" which occurs when you use one board for different tasks without sterilizing the surface after each operation.
Don't cut raw meat on a board, especially chicken, turkey, and all store-bought ground meat or sausage, then use the same board to cut up veggies for salad or to prepare some other food that will be eaten uncooked; you'll be eating raw meat and any pathogens in it if you do.
The issue is fairly easy to avoid by simply using different "coded" CB's for different stuff. We have three sets of boards: white for raw meats, green for veg, and blue for fruits. If, for instance, it's a mixed protean meal, like surf-n-turf, two white boards are used.
Our working boards are HDPE plastic that get cleaned with chlorine bleach after each use and then run in the dish washer.
I also have several wood "carving" boards for cooked meat only.
We could replace our plastic boards with wood, but wood doesn't look very nice after repeated chlorine bleachings.
If you have trouble storing different boards, you can minimize your risk through a work-flow routine where you make the salad first, then to-be-cooked stuff second, and the meat last, followed by a sterilizing wash before the next use.
