Port Orford Cedar Lumber
On the East Coast?
Saw the article in FWW. I would like to make that bench for my side yard.
Looked in Woodfinder - nothing close to North GA.
Alternative woods or sources?
Thanks
On the East Coast?
Thanks
Re: Port Orford Cedar Lumber
John Veerkamp
POC grows in a relatively small area on the Oregon coast. More properly called Leyland Cypress. It is used in lot in timber frame construction. My son and grandson work for a New Hampshire company (Benson Woods) that uses a lot of it. Nice wood with a great smell when machined. I've turned some pieces from it. Generally fairly plain blond with very straight grain. Rot residence should be similar to other cypress varieties.
TomD
Best bet is to move to Japan where they are stock piling all they can get. Used to be in high demand for arrows.
Not Leyland Cypress. Lawson cypress - entirely different species and genus. Same taxonomic family though.
Believe me - I wouldn't mind getting rid of my Leyland cypress.
John Veerkamp
Thanks for the correction JL, I misremembered. (CRS)
Use cypress
All the cypresses I know, including Port Orford Cedar and Alaskan Yellow Cedar, have excellent durability for outside uses. In Georgia, you can't be far from all sorts of cypress. Just be sure to use only quartered or slightly rift boards, as flat-sawn ones tend to delaminate on the grain lines, and you end up with little raggedy-edged rapiers curling up from the surface.
Thanks
I may go down to SC to get some - if I can't find it in Atlanta.
Re: Port Orford Cedar Lumber *LINK*
DizD
You might want to see if Atlantic White Cedar would be suitable. It is the same genus as the Port Orford. I just checked the specs and it seems the AWC is not as hard or strong as Port Orford. I know it weathers smoothly without all the problems baldcypress exhibits - more like western red cedar. Gates Milling has a good information sheet on AWC.
Don't know if they sell retail, but you could call and see. No affiliation, etc.
http://gatesmilling.com
