200+ woodworking book reviews
Question
Question
Question
I was passing by a construction site on Vancouver Island and saw a pile of laminated fir beams. I have never seen this construction before. Does anyone know if it is/was common?
Re: Question
Re: Question
ChuckInND
Because of the way that the 2 x material is positioned, it makes me wonder if the beams lay flat. How long are they ?
Re: Question
Re: Question
C. John Hebert
I worked on several high school Gym,s back in the 70's that used laminated beams and arches.
Re: Question
Re: Question
C. John Hebert
Also...many churches, also used this method
Re: Question
I'm with C. John
Gary Smyth
In the 70's and 80's the engineered structural wood group pushed laminated wood beams. Schools churches, even bridges were targets. Around here even some of the local parks used them in their covered shelters- some quite large. Haven't seen the same push lately but then again not looking for them.
Re: Question
Re: I'm with C. John
C. John Hebert
I'll tell ya though...it was some of the hardest and most physical work I've ever done. 2 cranes had to be used. One on each side, and perlins had to be hooked up and bolted into the main arches and spreaders were pulled up by hand. whoa
Re: Question
Re: Question *LINK*
Ryan
Laminated beams are used a lot in both residential and commercial construction in BC. One of the most impressive construction projects was the Richmond Oval built for the 2010 winter olympics
http://www.naturallywood.com/sites/default/files/Richmond-Olympic-Oval-Case-Study.pdf
Re: Question
Wow, nice shots, Gary. I've used laminated beams on construction projects myself, but I've never used ones that were wider than one laminate width. It makes sense that if you want wider ones, you'd stagger the joints. That's what I hadn't seen before, at least not an endgrain view.
Re: Question
Re: Question
Ralph Lipeles
I believe I have. My son lives in New Jersey. Not far from his home is a park with some nice walking trails. Over some of the swampy areas they have bridges whose main structures are a pair of laminated beams. As a woodworker I find the bridges very attractive.
Re: Question
Re: Question
ChuckInND
I know it was a stupid observation that I made. I made it on the basis that wood is stronger if setup on it's side. I would think that the beams would be a lot stronger if it was laminated plywood. But what do I know ?
Re: Question
Re: Question
William Duffield
All else being equal, laminated plywood would not be stronger, since the grain direction in half of the plies is running perpendicular to the direction where they would provide any tensile strength. Plywood would give some small additional strength against twisting and bending forces, but those are taken care of by the sheathing that is laid over and fastened to the tops of the beams.
Re: Question
Fire *LINK*
Bill Howatt
My father built a Shell gas station many years ago using the laminated beams in British Columbia. I heard at the time the claim was they stood up better in a fire than steel which really seemed counter-intuitive.
I Googled and found this which indicates that it is true, primarily due to the insulating effect of surface charring.
Bill
Laminated Beam vs Steel in Fire
Re: Question
Nice article. Good to know. Thanks!
Re: Question
Re: Question
Many years ago I attended Va Tech. (Back when you might have to out run a T-Rex on the way to class) The basket ball arena had laminated arched beams that spanned over 200 feet if I remember correctly. It must be about fifty years old now.
Re: Question
Re: Fire
John in NM
When we were gearing up to plaster our house (outside), I wanted to use vermiculite in it, for a little added insulation and also to make the stuff lighter when applying it.
As luck would have it, one of the producers of steel beam fireproofing compounds is in Albuquerque, and sold 10 lb bags of vermiculite as a side line (that is 4 cubic feet - bags are huge :D ). Their primary business is making a portland cement, vermiculite, and fiberglass mixture that insulates steel structural members from fire - steel's modulus of elasticity starts dropping rapidly with temperature above a fairly moderate 800 F.
Before that I never realized that steel structures were so vulnerable to fire, but in hindsight it seems obvious.
Re: Question
WOW, incredible building, thanks for sharing
Keith Newton
you say one of the most, I'd like to see any others that you know of and can share a link to.
Re: Question
Re: Fire
Too late to help you now, but I hope the vermiculite did not come from the W R Grace Company or their mine in Montana. That brand of Vermiculite contained a carcinogen. An unusual form of asbestos that was difficult to detect, but very dangerous. If you got the "wrong" stuff, I guess the danger is somewhat abated by encapsulating it in the plaster and then painting it.
Re: Question
Thanks for posting, very cool!
Re: Question
Re: Fire
Yep, when I was a young lad, I visited a large new car sales building in Wilmette, Il owned by my cousin and a partner. My brother was sales manager and Vp of the Chevy sales business. I noticed large wooden beams in the service dept. As this was a relitively new, mostly modern construction building of glass and metal I questioned why wood beams were used. My brother told me they got a large discount for using wood instead of metal beams due to the fact the roof would hold up much longer in the event of a fire.
Re: Question
No worries...
John in NM
IIRC, that mine has been closed for decades. Various asbestoform minerals are found with vermiculite, the most common being chrystotile, the relatively harmless kind (also called long fiber asbestos).
Getting a geology degree in the early 1990's, I heard a lot about the various types of asbestos :D
EDIT:
Incidentally, I found that the vermiculite additive had several positive effects on the two types of plaster we were using. It reduces cracking problems by adding lightweight bulk without reducing strength the way too much sand seems to do, and with lime plasters it somehow makes the stuff even stickier than it was already - no idea what the mechanism is there, but the empirical effect is very noticeable.
