The reset button on my Steel City bandsaw is tripping within seconds of my turning it on. Three months ago I had to replace the switch. It has been working just fine since then. I've checked the guides - they are all still set correctly. The tension has not been changed (because the blade has not been changed for quite some time). I cannot think of anything else to check.
Anyone have an idea what might be wrong? Could the motor be failing?
Since you just replaced it. Also just because it was a new switch, doesn't mean it is perfect these days. Unplug the machine, then start checking the circuit with a multimeter. Is the saw a 220v? One leg may not be making connection in the switch.
Check your wheel bearings (and guide bearings). I've had corrosion problems with my Steel City 18" bandsaw, and their turning resistance has increased substantially. I'm going to have to pull it apart and probably replace most of the bearings. My shop is not climate controlled, and that probably exacerbates the problem, but I've not had problems with my other machines.
IIRC, Steel City put TEFC motors on all their bandsaws, so there's no place for dust to get into the motor. Of course, sawdust could restrict air flow over the external cooling fins.
I don't know how to check bearings. I did run it without a blade to see if it was binding - but it still tripped after a few seconds. I do know how to take the motor off, so I can take it to a shop to be checked.
I had out of town company for the past few weeks and had no time until today to get back to it. Thanks for the suggestions.
I did not think it would run at all with a bad switch. I can certainly pull it out and check to be sure I connected everything tightly when I replaced it.
You haven't told us which Steel City bandsaw you have.
In any case, the motor drives the lower wheel via a belt and pulleys. If you remove the belt and the motor still trips, it's either the switch or the bearings in the motor. If you remove the belt and the lower wheel spins freely, it's probably not the lower wheel bearing, but if it is still difficult to turn with no load on it, you should strongly suspect its bearings.
If yours is the 18" or 20" bandsaw, then there is another system that could be at fault: the manual brake. If you stand on the break pedal, the lower wheel should be very difficult to turn. If it is the same with or without the brake pedal depressed, check to make sure the brake mechanism is not jammed in the actuated state. When the brake pedal is released, you should see the brake belt tension also release. The brake belt wraps about half way around a wheel on the end of the motor shaft.
Odds are you would hear it long before they were bad enough to trip the motor. The few times I've had bad bearings it has been obvious from the sound - and unfortunately, most motor housings I've seen in the last 20 years are so lightly built that once the bearing starts dragging a bit it spins in its pocket and you basically need a new motor. One or two I've gotten away with adding some shim stock around the bearing, but that is a really hosey thing to do.
If it's tripping almost instantly it's probably the off button not releasing the magnetic switch part. If it starts up and actually runs for a second then that probably isn't the problem. Another possibility if it has a brake is the interlock on the brake may be bad. But again this will usually not let the lathe start other than must a brief try at starting.
Can you try it in a different electric receptacle?
Are you running it on an extension cord?
Could be an electrical problem.
BTW, my Steel City bandsaw was struggling a few years ago and one day there
was a big bang inside. Turned out to be the shaft from the motor had cracked. I suspect it had bent before cracking. Anyhow, I called Steel City and they sent a new one, acknowledging that that was a known problem with the saw.
I scanned this thread and didn't see if the bandsaw was plugged into a dedicated or shared circuit and if it was a 110v or a 220v circuit. Unless I missed it, more info would help. Is the circuit breaker what is tripping?
If 110v, is it on a GFCI circuit? My lathe would repeatedly trip a GFCI but for a known reason (the VFD) but if your bandsaw developed a ground problem OR something else on the circuit has a grounding problem the GFCI might trip.
I would first test the circuit with a plug-in circuit tester. If a shared circuit, I would then try unplugging everything else. Then I would try plugging into a different circuit if possible. Then if possible, check the circuit voltage, preferably under load. I would then try connecting a separate ground from the frame of the bandsaw to the circuit ground. If any of these things work it might be a clue to the problem.
If the "tripping" you mention is of the circuit breaker in the electrical panel, note that breakers do occasionally go bad and need to be replaced.
This is almost above my pay grade, but there are a couple of things I woudl try. If you can remove the drive belt, spin the motor by hand (with it unplugged). The motor should turn easily and freely. It should be smooth and silent. If the shaft feels gritty or it makes a grumbling sound, you probable need new bearings. Same thing if its really stiff and hard to turn. Also spin both wheels on the bandsaw with the blade off. Same thing, They should spin free and smoothly. If they feel gritty, you need new bearings.
But, the fact that you say it trips with in a very brief period of time seems to indicate the shaft or shafts are locked and the motor can not spin up. If you don the things above, you will find the locked shaft. Also check the blade brake if there is one.
And short of a locked shaft, this sounds like an electrical problem. Could be a defective switch or a failing breaker. (Is the breaker that is tripping the one in the panel, not one in the machine?) Have you managed to create a short in the machine or wiring.
