Two Versions
I took the upgrade on my 8 y-old w-7 desktop.
I also just bought a w-10 laptop.
While I like 10 on both, the upgrade version has had several issues, not the least of which is the "Runtime Broker" utility that was constantly choking and freezing until I learned how to disable it. I also have frequent (1-2 a day) crashes of Firefox and Adobe Flash on the upgrade machine. Have updated those programs several times since the upgrade, but they still don't seem to play nice with the upgrade 10.
I have had "0" of such issues with the laptop which is, naturally, a full "clean" install of the OS.
My IT guy has told me that he avoids such upgrades as they never seem as clean as a full R&R if he wants to change to a newer OS.
Depending on what you use your computer for, the free upgrade may work fine for you, especially so you get used to the new interface before you buy the new machine.
One thing to note is that MS apparently did away with the data transfer utility in 7 and prior so moving stored data from old to new machines may be something of an issue, especially if you change from a 32 bit CPU to 64 bit.
