Carpenter bee trap plans
Does anyone have plans/picture of a trap proven to work?
Re: Carpenter bee trap plans
Ralph Lipeles
No trap plans but I also have carpenter bees here in Connecticut. If they are flying I use ant and roach spray. It works good. Wasp and hornet spray doesn't do anything to them. If they are boring into my deck, I wait until they are into the hole and then shove a glue covered 3/8" furniture dowel into the hole behind the bee. When the glue has dried, I trim the dowel with a flush cut saw and then stain the dowel end.
This is what I use
Lee Schierer in McKean, PA
I use a badminton racquet.
I wait until they hover and then whack them. I'm best with my back hand.
A few years ago, I made one like this.
I don't have plans, I just did it free hand from the photo. It caught a couple of carpenter bees, some wasps and a few flies.
I got more with the racquet than the trap.
Lee
Re: This is what I use
jcousins
we had lots of carpenter bees - i don't think they are successfully attracted to any kind of trap - cause they like wood - my porch, fence , wood shakes - actually had to replace part of a porch overhang because they destroyed so much over the years.
and i used a squash racket - a very satisfying thunk - but did not really eliminate the problem.
when they burrow into the wood the tunnel frequently makes a sharp turn. i found some drying powder/poison (known as a desiccant) - came with a small bellows and a long flexible nozzle. find their holes - after dusk, when they're back inside, blow some poison way down in the hole - then plug it with wet paper towel - and they never came out.
now if someone knows how to get rid of a trumpet vine????
jerry
trumpet vine....easy
cut it off and paint stem with any brush killer. Trichlopyr is most effective but others will work
Re: trumpet vine....easy
PhilIp Duffy
Good friend of mine has his 8yr old grandson shoot them with birdshot 22 ca. He has quite a pile! P.
Walter Barbier
I use 3M spray adhesive. If I catch them flying, they stop. If I catch them in a borehole, they don't ever come out.
I wound up painting the deck (actually a 41 ft ramp) with oil based primer and paint to keep them from boring holes in it. They no longer bother the ramp.
They do still come around looking for bare wood so I keep the spray can handy.
Don't trap, destroy
Years ago I developed a guaranteed, sure fire way to get rid of carpenter bees. Traps will catch a few. This method simply wipes them out.
When we moved to this farm around the wood house, barn, and outbuildings I saw hundreds. After applying my method, the next year I saw maybe 6.
I tried lots of things and this worked:
1. Modify a pump sprayer to give me a 10' wand to reach the holes. I cut a brass wand in half and soldered a long piece of copper tubing in the middle. I taped a 1x3 to part of the tubing to let me control it better. Set the nozzle to make a stream rather than a spray.
2. Mix up a solution of Sevin. I used the kind that is already mixed with water; easier than mixing the powder. I buy it at the farmer's co-op.
3. When the bees are active, raise the nozzle until it is in contact with each hole and fill the hole with the Sevin mixture. I pump until it will take no more or until it runs out another connected hole.
Any queens in the holes come right out and fall to the ground and die. Any eggs that the Sevin missed and hatch out later have to travel down passageways coated with the insecticide. If so, they won't live long. This seems to break the cycle of the bees coming back to the place they hatched to breed again. I don't know if that part is fact or just wishful thinking, but what works, works.
This is less exercise than whacking them with the tennis racket and less fun than shooting with 22 shot shells. Note that the ones buzzing around aggressively are the males and getting rid of even most of them doesn't help a bit. The females are the quiet, passive ones crawling in and out of the holes.
Spraying with wasp/hornet spray is a huge expense and you end up getting the stuff on your skin and in your lungs AND you mostly miss the females unless you happen to see them coming out of the holes.
4. Optional step. In late September when any that are going to hatch are gone, stuff the holes with steel wool then putty. The bees can drill through putty itself but will give up when they get to the steel wool! The next spring, repeat the Sevin treatment with any new holes.
This method is guaranteed or your money back.
Re: Don't trap, destroy
Thomas E Norton
I like this idea. Did not know Sevin was available in a form to be dissolved in water. I have always used the power with a duster.
I think it's just concentrated powder pre-mixed with water. You can mix the powder in water but the pre-mixed is a lot easier. I've tried the powder in a duster but it is impossible to get it very deep into the carpenter bee holes.
For pumping into carpenter bee holes I mix it in a higher concentration than recommended for spraying on plants.
Amazon sells it, as well as zillions of other places:
http://www.amazon.com/Sevin-Concentrate-Bug-Killer-Quart/dp/B000RNEYBG
BTW, I use sevin sparingly in the garden, and apply directly to the leaves or stems only when absolutely needed. (at the base of vines for squash borers, etc) As a beekeeper, I cringe when I see someone heavily covering plants with powdered sevin. I once saw a neighbor less than a mile away cover his FLOWERING green been plants with so much sevin it looked like snow. Honeybees will accidentally carry it back to the hive. If this one guy did that I'm sure millions of others have. With ignorance like this it is no wonder honeybees are in trouble.
Fortunately, it looks like it is harder or impossible to find big bags of sevin powder anymore - can't even buy it at the farmer's co-op. The powder is only available in smaller and more expensive shaker cans which makes it harder to abuse.
