A55 Smoothing Plane
End Grain Wood Sealer
David Frame
Hello Everyone,
Is here another material that will seal the end grain of wood other than End Grain Wood Sealer? I have heard that thinned downed finishes will do the job. Is this correct, or am I barking up the wrong tree?
Thanks for your time,
David Frame
Re: End Grain Wood Sealer
2-3 coats of latex paint will do fairly well if you don't have any AnchorSeal.
Just slop it on thick
Dick Coers
Are you talking about fresh cut timber? Thinned solvent based finish won't work because of all the water in the wood. I've had some luck with slathering on old glue, then imbed a sheet of glossy paper (old magazine or glossy ads from the Sunday paper) in the wet glue. Keeping it out of the sun and wind is also important. Not enough air movement though, and you get mold. If you are talking about pretreating the wood before staining, a wash coat of thinned shellac does the job. But again, not enough information for us to help a lot.
Assumption
Was for a freshly cut log to retard checking. If incorrect, disregard. :(
On the other hand . . .
Yonak
..If you're talking about an end grain cutting board, sealing the pores is not necessary (unless you have misapplied a poor wood choice, such as red oak) and some, indeed, say contrary to good practices.
Clint Searl
Acrylic roofing cement
Wood turners often use wax *LINK*
Grant in Iowa
Wood turners will often use wax to seal end grain on turning blanks. I see no reason it shouldn't work on longer boards, given the right vessel to melt it in.
I know one guy who frequents thrift stores and picks up candles, then melts them down for this use. It appears that colored candles don't pose an issue.
Wax appears even MORE effective at sealing end grain than anchor seal, from what I've seen.
An old hot plate and a 5 lb coffee can is about all you need.
FWIW,
End sealing with wax
David Frame
Hi All,
I have problems controlling the moisture in my shop. 85% of the wood in my shop has been kiln dried. I worry about moisture problems in the shop air and drying that may check the end grain in the boards and planks and possibly even honeycomb in my oak. A friend gave me a professional dehumidifier when he closed his carpet business. It is used daily and it's normally set to a medium drying setting. However, when I build wood project, I cut my wood just oversized and store it in my home for at least a month. I'll then check it with my Lignomat Scanner SD moisture meter. If it is in between 6 and 8%, the wood is ready for use.
My main concern is the wood in my shop. Am I doing something wrong? Can I control the end grain from checking? I would be grateful for ya'lls help.
Thanks for everyone's time,
David Frame
Grant in Iowa
David,
The answer depends on where you are located, as there are many climates to think about. let us know where you are and the climate details and we can give a better answer.
Having wood kiln dried is useful for many reasons. It isn't necessary, however. Kiln dried lumber doesn't magically control expansion and contraction afterwards, though the changes in the cells of the wood can help with the effects, or so I have read.
I have a 1400 square foot insulated woodworking shop with several thousand BFt of wood flat stacked in three floor to ceiling A-frame racks. I harvest logs, end seal them with two coats of anchor seal, then have them milled by an acquaintance with a Woodmizer. I sticker and stack the lumber outdoors, covered with sheet metal on the sunny sides and top. I usually wait around two years before considering it ready to come inside, though seasonal timing also figures in. As I bring the lumber in to the shop, I generally skip plane it before placing it in the racks. Moisture content varies between 9 and 12% generally when I bring it in, depending on time of year. This also happens to be typical range of MC on finished projects within my air conditioned and well insulated home here in Iowa. I want my lumber at or near the MC of the place it will ultimately be, so this is part of why I am not much of a kiln drying person, with cost being another factor. That said, Kiln dried wood will still reach equilibrium with the space it is in.
I also cool my shop with a 7000 BTU air conditioner mounted in the wall of the shop. I get the benefit of both the dehumidification AND a cool shop in summer by doing this. Winters here in Iowa are cold enough that the moisture doesn't need removed during winter, generally. Your mileage may vary, depending on your location.
One drawback of a dehumidifier is that the net output is heat, due to the compressor and blower fan. OK during winter, but just adds to summertime heat in my region. Know that a dehumidifier is just an air conditioner with the condenser in the same space with the evaporator. Makes no sense, in my opinion, to run one where i live. I'd much rather install a small window air conditioner in an exterior wall, and get the benefit of a cooled AND dry shop for the same cost. The water that drips from a window air conditioner is coming from the inside air. Amp per amp, you remove about the same amount of water. Might as well be comfy too.
If you live somewhere that is often cold and damp, or have other considerations to think about, then it might make sense to run a dehumidifier in your situation. A basement shop would be an example.
Overall, I try to keep my shop between about 55 degrees and 75 degrees year round. I have done the math, and running the window air conditioner around the clock in auto mode costs me around $12-$15 per month at most. It runs from around mid-June to mid-September. My shop is built such that two sides are about 4' below grade, so I am sure this helps keep things efficient.
I should also say that I keep the shop doors and windows closed unless the humidity and temperature are in my preferred zones.
FWIW,
Grant in Iowa
David Frame
Hi Grant,
The end grain information you gave me will help in the long run. Right now, I'm having foundation work on my home because of the hardwood trees on my neighbors property. The trees roots (A Live Oak and a Water Birch) are destroying my foundation and the patio slab in the rear of my home. A crew is working on it as I'm writing you. When it's is finished, I plan on installing and sealing a flat steel door in the rear of my shop adding a 5000 BTU A/C window unit to it. All I have at the moment is a dehumidifier. It does work, but you're right. It puts out a lot of heat.
I live in Lafayette, LA. It's in the south central part of the state. Needless to say, I have serious moisture problems. Louisiana's year round moisture content is about 70%. When I build furniture for a client, I mill the lumber slightly oversized and bring it indoors for several months. At that point, I check it's moisture content monthly. When the indoor moisture readings assimilate, mainly in the fall and the beginning of winter, to 6 to 8%, it's ready. By the way, I keep all of my figured and most expensive domestic and exotic woods in my spare bedroom. My wife is always grumbling about it. However, when I sell the furniture and whatnots I build, she objects a lot less.
I've had to many problems not allowing the wood dry properly. We, as woodworkers, are not perfect and we work with a material that is as perfect as GOD made it, but we do learn from our mistakes. Sometimes those mistakes are costly. But without making mistakes, we learn nothing.
I've been working wood for 44 years. I've made many blunders during this time. All I can say is that after all these years I've become a better woodworker. I'm not perfect, but I learned many valuable lessons. The one thing that is most important to me is to respect the customers wishes. I love my medium, it's,
texture, and the shaping of it. I'll continue working wood until I am no longer able to.
My father was an artist. A really good one. I didn't meet him until I was 26 years old. It was hard to get to know someone when both father and son are shaped in a different way. What he did give me, were his genes. For that, I'll be forever grateful.
Thank you for taking the time to read this and the patience you've shown trying to help me.
David Frame
P.S.
Grant, I was wondering if you can send me a photo of your A-Frames for storing your lumber. If it saves room, great. I need to look at it from a different pair of eyes. My wood is stored side by side with the thickness facing anyone looking at it. I also have sheet goods. I need to figure a way to maximize my space. I do not have a lot of room to store my material. The whole shop is only 500 SQ. FT. and all of my stationary tools are on casters except my Unisaw. Maybe you can show me a way to store my woods to help keep them in there place. I have about 4500 BF of lumber.
By the way, if I melt paraffin wax and dip the end grain in it, will it help keep the end grain from the problems we usually see?
Again Thanks.
Re: End Grain Wood Sealer *LINK*
Grant in Iowa
David,
Below is a link to a shop shot of the original "half A-frame" unit I built at my old shop in 2004. The idea was born of wanting to store both lumber and sheet stock, as well as use a minimum amount of materials. Further, I wanted to put as little pressure on the wall as possible.
I moved that rack to my new shop in about 2007, and added a second really A-frame rack to house my lumber. Then, in about 2010, I added a third. They are all full at this writing with about another 1500 Bft of lumber outside. And, I have three logs (2 cherry and 1 white oak) at the sawyer waiting on what I am felling this weekend, which is another cherry tree that is on the large side for Iowa.
The newer versions are free standing, and have two sides just like my drawing in Shop Shots. I have added a piece of 1/2" plywood to the inside surface of each side to prevent racking.
Let me see if I can snap some photos of the newer versions tonight...
Regards,
Grant in Iowa
Lumber rack original
