finishing ?
finishing ?
finishing ?
lestergillett
I am ready to finish my end table and have a question. Its White Oak and I found a finish in the
American Woodworker and that what I will use. It calls for a base color of Honey Amber and then
a seal coat of Shellac then a glaze of gel Walnut. What I have a question is do I need a grain filler
be for the glaze is added ? If so I will need to color the grain filler but what color would I use ? I
have some left over wood I will try it on to be use its what I like. I will then put a top coat of some
type to seal it in.
Lester
Re: finishing ?
Need More
1. A picture of the piece would be helpful
2. Your Honey Amber is: a) oil stain/finish b) an NGR stain (like TransTint in alcohol) c) a toned coat of shellac, d) ______________?
3. Are you looking for a "piano" finish with filled grain or just to color the pores?
4. Are you using the glaze to push the color evenly or to highlight details like beading or molded edge or leg details?
5. What top coat are you planning to use?
Re: finishing ?
Re: finishing ?
Dick Coers
If you fill the grain, the glaze won't have anywhere to go except for in corners and around moldings. I guess you can dry brush it to leave some on the surface, but I would have to see an example of what you are trying to achieve before I can direct you much more.
Re: finishing ?
Re: finishing ?
Alan Hollar
You are moving into a finishing schedule much like a factory would use. The initial color establishes a tone and evens out the base color, whether it is an oil stain or a dye. The glaze can be applied and manipulated in a variety of fashions, but for oak, the most common application would be to wipe lightly, allow to dry a bit, and then strike out the glaze with steel wool to accentuate the grain with lighter and darker areas. This gives a more dramatic appearance and creates a lovely randomization of the color depth. The glaze can also be allowed to accumulate in the corners and crevices of detail to add dimensionality to those elements. I would top coat with a spray finish to avoid the possibility of rearranging the glaze color. Lacquer, varnish or poly would work. I have no love for water borne finishes, but one might work if the glaze and finish were compatible.
Re: finishing ?
Re: finishing ?
Lester Gillett
Thanks guys that's what i need to do the finishing. I my using transtint for the base coat and will
you poly for the top coat. will take some photos of before and after.
Lester
