Enough Vacuum? Nope.
Grant in Iowa
Tom,
The above posters are correct about a shop vac style collector not being adequate. Shop vacs use high static pressure, and a relatively lower volume of air to move material in to their collection bin. This means that once you open the collection funnel up to the size required by a tool like a miter saw, there isn't a lot of air moving, and any dust can fall out of suspension or just go anywhere other than the shop vac.
In contrast, a true Dust collector with a minimum of 4" duct can be effective with a well designed hood. A 6" duct and north of 1200 CFM with a Cyclone is better. I have a Dust Gorilla DC with 6" ducting and blast gates. It is only about 15 duct-feet from the saw, and I have decent results with a hood similar to that in Marks photo. I have toyed with different configurations and ultimately landed on the inlets being slots along the bottom rear of the hood. I will try to post pics once I get home.
I further improved collection by using movable sliding doors left and right of the saw. This allows me to reduce the size of the opening when the saw is at its usual 90 degrees, resulting in an increased concentration of air flow where it is needed. Adding a 90 degree PVC elbow to deflect chips downward from the saws factory outlet helps deflect the dust downward towards the hoods inlet ducts.
Let me be clear here. (semi-rant mode on, I apologize in advance) The chips that will fall in to a bag on their own are only a nuisance, but it is the fines that remain airborne which are a health hazard. Swipe a finger across a shelf in your shop and think about what must be in your lungs. If you are operating an active wood shop with no real dust collection, you may just end up regretting it as you get older. Investing in a quality dust collection system is key to a long life as a woodworker with the power tools of today.
What your solution ends up being is up to you, but the decision also affects your loved ones both directly and indirectly.
If you would like to learn more about shop dust collection, I recommend Bill Pentz web site for more than you will ever find elsewhere in one place. I have linked to the introduction page, which is the best place to start.
Regards,
Grant in Iowa
