Dangerous
Ralph Lipeles
Woodsmith Tips just showed how to set up a drill press buffer using a hols saw as a mandrel. What they did not say is that if anything goes wrong you could end up drilling a 1 1/2" hole through your hand.
Dangerous
Ralph Lipeles
Re: Dangerous
Ron in Sterling, CT
I agree that the hole saw buffer tip is not a safe practice. I can just see my hand slipping and all those hole saw teeth doing what they are supposed to do -- cut whatever gets in their way, mainly my hands and fingers.
Ron
Re: Dangerous
John in NM
Not just that - if the chuck is on a jacobs taper shaft rather than threaded, a side load such as from buffing or milling can cause the chuck to come off while spinning. I've heard one machinist refer to this as a "bozo-no-no"
Re: Dangerous
Ralph Lipeles
All drill presses that I have seen that have a Jacobs Taper also have a threaded collar that does a good job to make sure that the chuck remains tightly in place.
Re: Dangerous
John C Lucas
Wow. I no longer get Woodsmith but i do a lot of buffing. How are the holding the buffing wheel, on the shank of the hole saw. I can tell you for a fact things can get away from you really really rapidly while buffing. Most woodworking drill presses ahve a #2 morse taper and can come out with side pressure. Ive had it happen.
You can buy mandrels designed to hold wire wheels and they only cost around 5 bucks. Now im not putting the guy down for being ingenius enough to do that in a pinch but i wouldnt run it in a magazine. I was tkps editor for American Woodturner for many hears and passed up some really interesting ideas because of potential safety issues
Sorry...but
Brian Roberts
I'm of the opinion that there is nothing wrong with what they show.
Living in fear of what "could possibly happen" is.....well.......not realistic.
So.........as woodworkers we face the responsibility to protect ourselves from all the "things that could happen"
Another poster recently mentioned "putting on our big boy pants".
I think that applies here also......
They aren't talking about industrial level buffing of ...ummm...motorcycle rims...or the like.....geez......nuff said.
Hey ....it's not like
Brian Roberts
they are putting one of those wool steering wheel covers on the radial arm saw blade and buffing with it......hmmmm....now there's an idea.....
Re: Dangerous
John in NM
I've never seen that, or perhaps never noticed it. I would have to see a drawing of what you're describing - its not obvious to me how this would work.
I've never had a chuck come off due to side loading - and I have gotten away with milling using one before I understood why one shouldn't do that. I did have a chuck fall off an import mortiser once, and would tend to be particularly careful of import drill presses.
Re: Sorry...but
Ralph Lipeles
It's not a question of living in fear but understanding what can go wrong and taking steps from preventing it.
Re: Dangerous
fredhargis
All they did was slip a 1 1/2" buffing ""sleeve" over the hole saw, I've not seen a sleeve like they had but it looked like a sanding sleeve with lambswool. But It didn't look all that unsafe to me. True, you need to stay away from the bottom of the sleeve, but that could be remedied by buried it a little in a board with a 2" hole in it for clearance (or just run it down to the table top). I did wonder how well it would work, the sleeve must have really been a tight fit on the hole saw; I just imagined it slipping. Like you I've never had a chuck fall off from side loading, but I must confess I don't do it a lot.
It's a paint roller....
Come to think of it....
John in NM
I've seen those sanding drums for years - probably not enough force to be a problem, in retrospect.
Thank you
fredhargis
it should have been more obvious to me, I'm guessing he mentioned that in the video but I had the sound muted.
I take it back fairly safe
John C Lucas
I had not seen the video. I finally found it. It would be pretty hard to get hurt. You could of course but then just using a hole saw can hurt you if you don't clmap the wood down. As far as side force releasing the morse taper. Yes it can but un this case it would just fall down. Ive had a drill press jacobs chuck come out when clening metal using a 4" wire wheel. No damage there either bjt it scared me for a second. I usually use a deablow mallet and tap the morse taper in if i have to remove it for some reason. Haven't bad one come out since i started doing that. I don't hit it hard enough to damage anything just a pretty good tap.
Re: I take it back fairly safe
TomD
Anyone who has worked around a 4 jaw chuck on a lathe is not going to get too freaked on a few teeth, run them against a grinder if one is really worried. However, a proper sleeve with a support for the free end cost about the same as 2 issues of that magazine, just how cheap are we.
Re: Hey ....it's not like - well actually
TomD
One should never underestimate the lowly drill press it is a killer, when things go wrong you can easily loose a few fingers. heck, my wife lost a finger getting something down off a shelf, it doesn't take much. She had fancy surgery, but if you walk through life without fingers people tend to look at you like you are wearing a dunce cap, though I guess that is the least of it.
Actually the radial arm example allows you to place the blade on backwards so that the teeth have positive rake, which is a lot safer than what they are doing. For years my disc sander was just such a rig on a table saw.
You did call and raise with that steering wheel cover, awesome! Send that in to the tips columns, maybe you can score something nice by LN, or LV.
