minwax stain marker drying time?
Keith Newton
I'm needing to do some details on a project which I'd like to use these pen's on. I've never used them except to touch up blemishes after all other finishes were applied.
My question is, Can I use it after using a minwax stain, but before using a wipe on poly, or will the spirits in that just dissolve the marker stain? And or how long should it dry before following with the wipe on?
Re: minwax stain marker drying time?
Howard Acheson
The best way to answer your question is to make up a sample board and apply the marker and then over coat it with the clear finish. As far as I recall, the solvent of the Minwax color pens is alcohol. As long as the pen coloring is dry, an oil based of water based clear coat should not affect it.
