Completely OT Cleaning a pan
My son (Boomerang Kid) burned something (cheese?) onto the inside bottom of one of my pans. I have soaked it for days. No luck. Any suggestions on cleaning it. I'm considering some 320 sandpaper on a pad.
Re: Completely OT Cleaning a pan
John Veerkamp
If the pan is cast iron or SS then that will work. If SS finish sand op to about 1200 grit. If the pan has the non stick coating it is likely dead. Nothing to lose by trying though.
Oven Cleaner before Abrasives
Howard Pollack
I've occasionally had luck with boiling water and a little bit of electric dishwasher detergent. Need to boil for a few minutes.
-Howard
Re: Oven Cleaner before Abrasives
Mark Mandell-Gone Round In New Jersey
test/cookie
Stuart Johnson
I had a cast iron grill pan that had something stuck that wouldn't come off. I solved the problem by putting the dry pan on a high burner and letting it come up to as high a heat as I could. I then poured in cold water.
The crud popped right off just prior to the pan cracking in two with a loud bang.
Tom Dunlap
Baking soda and vinegar paste on top of a dampened pan
Duhh!!!
It dawned on me as I was typing that I should try oven cleaner.
I will get some and try that before the abrasives.
The second pan has some sort of non stick surface so I don't think heat or abrasives will work. May try the oven cleaner under the premise you can't ruin something that is already ruined.
Stuart, Success!...EPIC FAIL!!! Like it.
Re: Duhh!!!
It will work better if you warm the pan, not HOT, just warm.
Re: Duhh!!!
I was thinking of setting the ;pan in some warm/hot water from the waster heater and spraying the inside. I will see how that works.
CJ in MPLS
That will work miracles on the inside of a coffee stained carafe or thermos.
boil water IN the pan
Grant in Iowa
Others have suggested it, but I think it may have been a bit unclear. Put water in the offending pan, then bring it to a boil on the stove. No danger since the pan and water heat together. Sure to remove all but carbonized foodstuffs (which may be what you are dealing with). Suggestions of adding detergents may also help.
Aluminum and dishwasher detergents don't mix. We keep all aluminum out of our dishwasher for this reason.
Go abrasive if that doesn't work.
FWIW,
Grant in Iowa
Re: Completely OT Cleaning a pan *LINK*
Hacks for cleaning scorched pans
Thanks, Got it.....
I bought a can of oven cleaner and sat the pan in a sink full of hot water and sprayed. Let it sit for about twenty minutes and wiped it clean. Saw two or three spots smaller than a period at the end of a sentence. Sprayed them again and got them out. That spray is nasty but effective.
Thanks for the help.
Of Course
Your wife has probably already told you "I knew that (but you never ask me)"
No wife....That's why I asked here
One thing...
John in NM
Oven cleaner will take the surface right of anodized aluminum pans - though obviously this wasn't one of those
Re: One thing...
TomD
I would be leery of that use. It may be fine, but my desire to experiment with product pretty much ended with the story of the guy who reset he brain to IQ zero by tig welding over a part that was cleaned with brake fluid. Who knew that created phosgene gas. And guys who can tig weld have at least some basic shop sense.
Re: boil water IN the pan
james runchey
Hey Grant...gotta tell ya on the aluminum in the dishwasher, my wife has been putting our Wearever brand aluminum pots in the dishwasher with detergent for many, many years with no problems. She bought the pots in 1952 just before we got married in '53.
Grant in Iowa
Interesting!
Not sure how, but aluminum items we put in the dishwasher come out looking like a well weathered bridge railing, kind of a dark gray and matted.
What type of detergent are you using? We use the little Cascade soft tablets.
Perhaps the Wear-Ever pans use a better grade of aluminum. Might be worth investigating.
Thanks,
Grant in Iowa
AZ in Colorado Springs
I haven't used a dishwasher in many years, but that was exactly my experience regarding aluminum. I was in the air force, so that happened in a lot of different states, not just one place maybe with cruddy water.
William Duffield
Many years ago, we stopped baking lasagna (and anything else with a tomato sauce) in aluminum pans, after a couple of them pitted all the way through the bottom.
