Want to build a ukulele
Ryan
A friend of mine in the Mesa/Phoenix area is looking for some wood to build a ukelele. Suggestions as to local suppliers... or is he better to look online?
Thanks!!
Ryan
Thanks!!
Re: Want to build a ukulele
John C Lucas
My ukelele is all made.from mahagony. That should be easy to find
TomD
I am making one right now, and it is predominantly wood from the construction site down the road. There was a large board of something very similar to Mahog. but it is heavier. I am going to get the whole guitar family out of that.
The Mahog in question is not the HD mahog.
It really depends what you want to do. There is lots of wood on ebay, be wary as some of it may be illegal to import. There is Hawaiian Koa there. The smallest Ukes have pieces so small they are easy to saw out of stock so you can make a superb instrument out of local wood, or exotic wood you might find anywhere. keep in mind that a lot of this wood should be quartered, and it may be difficult to find that locally in wider pieces.
The most important piece of wood is the neck, so be sure to put something really good in there. Playability will depend on the neck being completely stable or you will not be able to maintain tight tolerances.
The soundboard is of course also important, but some rather ordinary wood can be very musical, it just won't attract much attention to the instrument. Koa is sometimes used in Uke soundboards, but I would avoid it unless you want to use the instrument mostly in a rythmic way. It pays to decide in advance what kind of approach will be used on the instrument and what kind of strings will be used.
TomD
Oh to get back to the main question... You will get excellent wood from Stumac, or LMII. For that mater the forums, or ebay have good wood. Most wood sold for lutherie these days is pretty extraordinary. Anyone who wants to hang around will not be sending you junk. Normally the best wood you will work as a woodworker will be either for archery equipment or lutherie.
Mimf
Jorge Castañeda
Hi Guys, there is a forum called Minf, Musical instruments makers forum www.mimf.com
a goo source of info about building instruments, specially string instruments.
Check it out.
Re: Mimf
TomD
I find that place annoying and am not alone, several people have left over the years and tried to start alternative forums.
In the Case of Ukes, there is little reason, I would have thought, to look further than Ukelele Underground's builder's forum. Some real stars, like Rick Turner, drop in there from time to time, as well as builders whose biz is more focused on Ukes all the time and nothing but. There are also some good youtube channels.
There is an OK book, LV has it along with everyone else. I would not call it necessary, but fun to look at now and again.
