Slab to foundation joint seal?
Tim Greif - West of Chicago
My river house has a two car attached garage that we're turning into living space. The floor slab abuts the cement block foundation. I noticed this winter during extremely cold, windy weather, there is a cold draft coming up through various points in the joint between the slab and foundation. Before we close this up and lay carpet, I want to seal these gaps up. I'm not sure which is the best approach - either use expanding foam or use some type of caulk or driveway crack sealer, either the pourable type or the caulk tube type. Anybody done this before?
PIC below shows the joint. This is a cement block foundation wall. I've filled the block cavities and the slab is flush with the top of the foundation wall. The crack varies from nothing to maybe 1/8 inch depending on location. The outside north and south walls are the most susceptible to wind influence.
