Is T Track T Track?
Is T Track T Track?
Is T Track T Track?
Are they all the same? (I just got some Festools and am wondering if the attachments are interchangeable.) Can I buy any kind of T track and use them?
Re: Is T Track T Track?
William Duffield
No, there are several different sizes and styles. You definitely do not want miter t-track, because the clamps fall right through. And the Kreg mini-t-track and t-track designed for T-bolts doesn't fit either. While it is the inside dimensions that are important, it is most often spec'd on the outside dimensions. The track in my picture in the former post is 3/4" wide and 1/2" high, but there are people who offer 3/4" x 5/8" that the Festool clamps and other fasteners fit, too. There are also combo t-tracks with multiple channels in different sizes. If you find track which is spec'd for 1/4x20 hex bolts, it should fit.
Note that some of the track is 1/2" high, while others are 5/8" high. I prefer the 1/2" because it leaves more of the substrate for stiffness. In general the 1/2 track is installed with flat head screws; the 5/8" is installed with pan head screws.
The best strategy is to take a clamp with you to the store. Indra track fits, as does the generic track that Woodcraft sells. I found one clamp that would not quite fit in the t-track I usually use. The clamp's bend wasn't quite sharp enough. I easily fixed it with a file.
Rick L
Rick L
There's metric and imperial T track. I never believe opinions on forums. I don't know who the people are and their background. I would believe Festool T track is metric. Do your homework...
Once you taste the green koolaid
Dick Coers
You have to buy their accessories, sandpaper, etc. Wonderful marketing on their part. Charge more for the tools, even more for the accessories!
Mark Nowicki
From May 2009 Pop. Wood. article:
"All three plunge-cut saws ride and operate on a Festool guide rail. However, Festool’s saw rides on a Makita track, but not on a DeWalt track. And a DeWalt saw doesn’t work with a Makita track just as a Makita saw is not functional on a DeWalt track. "
You could have found this out for yourself.
Mark
William Duffield
Barry's not asking about the track that comes with the track saws. He's responding to a post I made in another thread regarding additional uses for the Festool quick clamps, when they're being used with something other than the Festool products that are designed to be compatible. It's here:
http://www.woodcentral.com/woodworking/forum/messages.pl/page/1/md/read/id/497250/sbj/another-festool-question-track-saw/
William Duffield
Yes, Festool is metric. To make them more usable in the US market, Festool has provided such things as Imperial stick-on depth scales in a very few cases, but one of those is not available for Barry's TS-75. Following up on what I explained to Mark, below, the issue here is not whether the T-track is English or metric, but whether you can slide the clamp into a non-Festool T-track (not a track saw rail) and have it hold in the track, like this:
I own and use one of the TS-75 track saws that Barry just picked up, and also rails and the quick clamps we are discussing. I also own several other Festool tools, and I formerly worked in sales for a Festool dealer.
William Duffield
Sorry for the late response. I just stumbled on nine years of experience on which T-tracks fit which Festool clamps. If you need to know, I think it's all in this thread on the Festool Owner's Group (FOG) forum. You might do well to start at the bottom of the second page, as over the last decade changes have been made in both clamps and in some of the T-tracks, too.
http://festoolownersgroup.com/festool-jigs-tool-enhancements/clamp-t-track/
