Is it a special size or base? There are lots of small bright LED lamps but you might need a 12 volt power supply. A 12 volt 'wall wart' might be enough.
No wiring required. No mounting problems. And, you could use it elsewhere when you weren't grinding, e.g., bandsaw, drill press, lathe, workbench, etc.
Ah, I really don't recommend one of those.I have one and the light just isnt that good in my opinion. Its ok in a pinch but not all the time. Other people that have them might have a different opinion though.
You're probably right; it works in a pinch. Most places in my shop, I have plenty of overhead light, and this one is just enough more that I can see the necessary details. I really prefer another work light I built, with a GU10 LED Bulb, 50W Halogen Bulbs Equivalent on an articulated arm. It provides much better light, but it's not always convenient, because I have to unplug it, find a dog hole and an outlet where I need it, and plug it back in. The gooseneck on the L-V light is a lot easier to aim when it's magnetically attached to a bandsaw door or a drill press head, etc. Always trade-offs! I'm still searching for the perfect work light, and I've sure found a lot of imperfect ones. The other problem with this and all battery powered LED lights I've found is that they gradually lose lumens as the batteries discharge.
