Another Festool question, Track saw
I have acquired a Festool track Saw at auction. I have two pieces of track and the bars to splice them together. I do not have any clamps to hold the track down. "F" clamps. Are they necessary? One video said to just lay the track down and use the saw. Seems unreliable to me. But at the price of the clamps I may try it. $39 for each clamp????? sheesh!
Re: Another Festool question, Track saw
John in NM
The clamps are useful if you are not cutting nice flat stuff. Other than that, they aren't required, the foam backing does hold the guide quite well. Once one has the clamps though, they often get used by default :D
So I'd say try it without and then see if you need them. The one thing I've had to do a couple times is replace the rubber lip that you cut through initially to make the guide kinda zero clearance. It does get worn and becomes less useful for dropping the guide on the mark and cutting (this feature is well worth replacing the rubber now and then).
Would you buy the cheaper knockoff.....
Version of the clamps? I saw some that were another brand and they were about half price. I have not adjusted to the Festool pricing structure.
Do you have their vac? Seems excellent, but very expensive.
William Duffield
The only times you really need the clamps is if whatever you are cutting is very slippery or is not in a horizontal position. But, sometimes I use them when working alone to temporarily hold one end of the track while I walk around and do a fine adjustment on the other end. After I have both ends precisely aligned with the track, I tighten the clamps, just to be sure.
I find the Festool clamps very useful around the shop, not just for Festool tracks. The first thing you need to know is that they slide into T-track. If you attach the T-track in a dado on the bottom of a fence, you can use it quickly and easily as a router table fence, oscillating spindle sander fence, drill press fence, etc. I haven't round anything else that is as easy to implement or as quick to use. Like the Festool track, the fence can be any length longer than the table, and it clamps just as easily diagonally across the table as it does parallel to an edge. You don't need tracks in the table itself, and the clamps don't stick up and get in the way of your tools.
Another way is use them is to hold an auxiliary fence to a table saw fence or bandsaw fence. I just drill a couple of half inch diameter holes in the top of the fence, which needs to be made from 3/4" thick or thicker material.I drop the clamps into the holes, and the shoe over the existing fence. Unlike F-clamps, they don't get in the way of whatever it is you are sliding against the auxiliary fence. For example, here is a taper jig, captured by the L-shaped fence that is in turn clamped to the table saw fence.
I use the same technique for holding flip-up stops to the fences of cut-off sleds, etc.
I've never shelled out for the more expensive ratcheting Festool clamps. They work more efficiently (quicker), but since I'm not using them hundreds of times a day, they aren't really necessary.
If you get the Festool clamps. or a substitute, check to make sure they fit your T-track. The Festool clamps fit Incra track and other generic track, but not the Kreg mini-t-track.
Thanks Rick, I watched that.....
It was very helpful. Festool is very new to me and I am learning. I don't remember the clamps being mentioned in your video, but I will go look again. thank you for an excellent presentation.
Thanks William, As I told Rick....
this is all new to me. You have given me some good ideas. Now that I know the clamps are so versatile I don't feel so bad about spending the money. I have no idea how much use I will get out of the track saw and I just hated the idea of buying two highly specialized clamps and "filing" them away with the saw only to use them once in a while. If I can use them around the shop, I'm in. Now I just have to remember to take them with me when I use the saw. Thanks.
Re: Thanks Rick, I watched that.....
Rick Christopherson
The track is surprisingly stable without the clamps. If it's convenient, I'll use them, or if it's a small piece that's prone to move. Most often I just use them when I can't afford to take any chances.
Oh, when you're not using clamps, remember to periodically brush any sawdust off the foam strips. The sawdust can make them slip.
Re: Thanks William, As I told Rick....
Rick Christopherson
When I first got a tracksaw (old ATF55) over a decade ago, it was a freebie and I wasn't super impressed. Oh, I forgot, but that happened right here on this forum. I was critical of the company in a forum posting, and the CEO used to read this forum, and sent me an email the next day.
At the time, I realized I couldn't give them a good review. So I instead decided to rewrite their poor manual. But during that process, as I became familiar with the saw, my impression changed.
Today, even though I have a grossly over-equipped shop, I reach for the tracksaw more than any other tool. The older I get, the more inclined I am to reach for the tracksaw than to even fire up the tablesaw. (But one will never replace the other.)
Re: Would you buy the cheaper knockoff.....
John in NM
I didn't know there were other brands that would fit in the slot. I bought them about 12 years ago, I don't remember them being all that expensive, but perhaps I've just forgotten.
I just use whatever shop vac I have. One of the best I've used is actually a Dayton, its specs (and price) were equivalent to the high end ones like Festool. I have one of those orange aftermarket hoses that Woodcraft sells, and with an assortment of rubber plumbing quick fix adapters I've always gotten it hooked up to whatever was needed.
fred in ct
Barry, I've had a Festool track saw for over 10yrs, couldn't imagine cutting ply without it, most of the time I don't use clamps but if I'm cutting mdf I do because of the dust, I got tired of the original hand turned clamps and didn't want to spend the coin for the Festool so I bought the Dewalt version for around $30 for two and they work great. I also bought the Dewalt carry bag because the Festool was too much for what it is, I know heresy for some.
Thanks Fred, This was
an impulse purchase for me. A friend of mine was looking at an auction site and Said "here are some tools, the auction closes in twenty minutes". I got this pile of tools for half price and they appear barely used. While pleased I still can't believe I spent the money.
Is having a Dewalt bag for your Festool Track like pulling out a Two Piece Custom Pool Cue?
I will order the Dewalt clamps today.
Thanks again Rick, I remembered
your posting here. It was one of the reasons I was lusting after a tract saw. Like all of us I am getting older and don't appreciate flipping panels around in the shop anymore. Not only that I have a tiny shop and a sheet of plywood looks like an aircraft carrier in there. I am fairly well equipped, but a track saw looked like it woudl be handy. I'm glad to here that you like yours and use it.
Mine was not a freebie, but a recent snow storm collapsed a crappy metal carport at one of my rental houses. The tenant did not want it back, so I took the insurance payout and bought a pile of Festools. Neat trick, huh?
Thanks again. Now to try to work up my nerve and buy a Festool Vac. Anybody think they are worth the money? Or not?
Re: Thanks Fred, This was
fred in ct
Barry, it's more like a snowboard case, it has a zipper that goes around 3 sides and opens up flat and has Velcro straps to hold the rails, I have two 55" and one 30" tracks and 2 Dewalt clamps and they all fit in with room to spare.
Re: You won't regret the purchase
Hank Knight
Barry, I'm in the same boat with you - getting older, tiny shop etc. I used to hate working with sheet goods, until I bought a trac saw. I'm still not crazy about sheet goods, but the trac saw makes a huge difference. I don't know how I got along without it all those years. I bought a set of the Festool clamps and I use them every time I use the saw. I don't trust the trac to stay put when I get it lined up, given my luck with that sort of thing. Like William, I have found other uses for them. They work especially well for clamping auxillary fences to my table saw fence. You won't regret the purchase of the saw or the clamps.
Hank
Worth the money
David Yoho
The Festool vacs are awesome good. I also hear good reviews of the Fein vacs. The Festool vac I have is used with my two Festool sanders only. I use a standard shop vac for general stuff. I like the fact that the pickup from these things is so good while sanding that there literally is no dust left behind or in the air.
Worth the money? To me it is.
Re: Thanks again Rick, I remembered
William Duffield
I have two of them, kinda. When I brought the first one home, SWMBO commandeered it.
Some advantages: They are equipped with hepa-filters. When the bag fills up and it's time to throw it away, none of the dust in it escapes. They ave very quiet. They don't make much more noise than the Feins. They will move 135 CFM. That's a real measurement with the filters in place and a hose connected, unlike some ShopVac manufacturers, who do their flow measurements without filters or hoses and the motor and fan wide open. When you are running them with a Festool sander, no dust excapes into the environment. This is important to people doing renovations in occupied houses and apartments.
It might not be important in suburban and rural Virginia, but the pros doing installations and renovations in the big cities consider the security features essential. All the Festool tools in their systainers latch in a stack on top of the vac, so they can be controlled with one hand across the sidewalk and up the elevators. If they have several separate tool boxes and a vac to watch and move, there's a much greater chance that some lowlife will abscond with one of them while they are handling another one.
