What a convenient discovery
AZ in Colorado Springs
I'm building a utility cabinet for a friend's laundry room. The other day I routed dadoes in the inside of the bottom, top, and back to house the center divider (a double thickness of plywood). I cut the dado using a pattern bit, so I could simply line up a fence on the knife marks made during layout.
Then, oops, the plywood I picked for a fence wasn't tall enough to guide the bearing on the pattern bit. OK, I moved that piece back from the cut line and used a thicker piece of scrap that was tall enough for the length of bit I was using (but it's only about 3" wide -- sufficient to support the router, but no place for clamps). The edges of that piece of scrap were both jointed, but not parallel. (The top and bottom faces were parallel.) No problem, since I was using a piece of plywood behind it (otherwise the clamps would have blocked the router) -- just clamp that piece however it butted next to the actual guide board. A little lateral pressure when making the cut kept everything in the proper position.
The discovery: because the piece guiding the router was sort of wedge shaped with non-parallel sides, I could slide it one way or the other to fine tune the width of the cut. And because it was not clamped itself to the project board, I could easily lift it away for a test fitting and then put it back in place and scootch it back a little to widen the cut by a hair.
Sort of a sliding-micro-bevel-fine-tuning.
