I suspect a few of you could presume to undertake this project, but I'll leave it to you to respond to this touching query that came in over the transom today...
Good Afternoon,
I would like to see if our unit would be able to purchase a custom
going away present for our Captain.
She is a Military Veterinarian and I wanted to get something like a
German shepherd with a stethoscope around its neck, to symbolize the
Military Working Dogs we see and veterinary medicine with the stethoscope.
We had a bunch of ponderosas come down in a storm over Christmas - some of the log wood is big enough to do a full size dog carving if only it weren't wet!
The principle is to be aware of the grain direction when using edge tools, especially ones like shaves and chisels that don't have limiters (e.g., a plane mouth) on them. Cutting downhill on the grain is a rule with green and dry wood both. Green wood is more yielding, which is a pro and a con, but success depends on your touch with whatever wood you're carving.
First don't use the whole circle, or if you do, drill out the largest hole that you can manage up from the bottom getting rid of the pith. It might work to even do some others around that one. After it is dry you can plug those holes on the surface.
Still better, is to work without the pith. It is not too unusual for the pith to be off-center, allowing there to be large clear blank on one side. Still even with that, try to stay out from the pith and juvenile wood.
While the carving progresses, I will use a spray bottle of water to keep any minor checking from starting if there are details that go slower in one area, leaving some others exposed longer.
Whenever I quit for a break, lunch, or overnight, covering the whole thing with a cloth, or box will slow the evaporation process. And when it is finished, I keep a close eye on it, knowing moisture loss will be fastest on endgrain, intermittently covering and exposing that, will allow the whole mass to come down at a nice slow pace, without building stress on the surface while the middle is still more saturated.
I have not ever worked green Ponederosa, and don't know if it is prone to blue staining. I would guess if it is, it would already be in there after this long, unless it has been cold enough to prevent it this long.
I would go a totally different route. I would turn a hollow vessel and then use prography to draw the dog on the vessel. Did that many hears ago when i took a class with Frank Sudol. The whole class did and it wa s pretty amazing how well we all did. Its just a matter of learni g to burn hair and tben paying attention to detail as far as how the hair flows around the body
I was thinking of Ranger sitting upright on his haunches, holding the stethoscope in his mouth. This would offer a pretty good shape for hollowing from the bottom.
I'm putting the finishing touches on a carved turned, lidded vessel using a Cecropia Moth chrysalis as the inspiration. I'll post some pics when it is finished.
I sent an email, asking if they had a budget, and deadline, but haven't heard anything.
