Getting rid of Kerosene smell????
In the second floor of the garage I am working on someone spilled kerosene, probably form using a kerosene heater.
Its a bare plywood floor. Any idea how to get rid of the smell? Anything soak it out of there? What to use to coat it?
(right now I have it covered with baking soda, hoping for the best.)
Re: Getting rid of Kerosene smell????
-When I was contracting (several years ago), I was occasionally installing and repairing oil furnaces. I always carried a bottle of commercial kerosene scent remover. I can't remember the name but it did a "fair" job of covering up / removing the smell. I purchased it at the local wholesale distributor of Heating/air plumbing supplies. As you are flipping homes I am sure you know of some in your area you can contact ~ I never saw any product like it in any other stores.
When there was obvious liquid, I have also washed the floor with a tide solution, it does remove quite a bit, and /or used Diamataceous Earth oil dry from the local auto parts store to soak up as much as it would prior to using the scent remover.
I can't say my methods were completely successful. However they certainly reduced the apparent odor a lot and I did not receive any customer complaints. I can't remember ever finding a home that used fuel oil or Kerosene to be 100% free of the petroleum odor when you were near the heating appliance (before I worked on them)!
Stuart Johnson
You might try covering the spill with fresh coffee (unused). It will remove odor from inside old trunks so it might work.
BrianMonumentCO
Two questions that come to mind are;
1. Does kerosene do anything bad to plywood or other flooring products?
2. Does it increase the flammability of the floor?
If it does either the affected flooring should be replaced.
Shellac
Dick Coers
or shellac based primer is the universal sealer.
John McGaw
Sealing with shellac is one way to go but if it is limited in area to one sheet of plywood then replacing it entirely will probably be cheaper and easier and will take effect immediately. How long can it take to pull up and put down a 4X8 sheet?
Jesper, Denmark
Jesper, Denmark
Coating Will not make much difference, as the smelly vapor will just come out of the underside. Heat and ventilation will eventually fix it.
AZ in Colorado Springs
That's a cruel suggestion. Barry's been down that road -- trying to match plywood thicknesses ... :o)
