Spray Guns
David Frame
Good Morning All,
I'm in the market for a new spray gun. I presently own a Binks Model 7 and 2001 with various, needles, air, and fluid nozzles. I also own three inexpensive gravity feed spray guns. The largest fan I get from the Binks guns is about ten inches. Both Binks guns work fairly well, but I need better atomization. I've been looking into a C.A. Technologies CPR setup which has twelve holes in it's fluid nozzle to give what seems to be better for atomization. It's a low pressure, high volume gun. I'm not in the market for a gravity feed gun, but siphon cup or pressure pot feed spray gun. By the way, the type of spray gun I'm looking for will be used mainly for woodwork. However, I will also need it for metals and plastics.
The compressor I'm using is a an ancient 30 gallon Speedaire that works as if it were new. The volume it puts out is 9.1@ 40 psi and 7.1 CFM.
I would grateful for someone that can point me in the right direction, .
Thanks for your time,
David Frame
