Re: Scaffolding Idea needed
TomD
Without being negative, the big problem with this kind of deal is that if you have to ask, you probably shouldn't attempt it, you are engineering on the fly. So all is well if the lift is affordable. Around here there is no way, it would be cheaper to hire the guy to do the siding, so long as he is insured.
The neighbour up the street just dealt with this exact problem. He did it by building a floor onto the roof, and simply went up from there. He had a roofline perp to the sidewall (which I imagine you would have said if you had also), and he joisted across the roofline, carried the loads outbound to the ground. As though he wanted to build a flat roof over the roof. He was doing a bunch of stuff there, and while he is a very efficient worker, that scaffold was up there for a long time. Exactly how to do something similar in your situation would depend, on... Everything. Pics at a minimum.
Whatever you do, don't trust your life to something nailed into a 12/12 pitch that doesn't hit a rafter. How do they nail without hurting the shingles? They fold the shingles back, and then nail. It requires a fair amount of skill to do it and hit what you are after, and not wreck the shingle, a hot day helps.
You can nail right through the shingle and a glob of goop will almost certainly reseal it, but you have extra material between the strap and the nail, you can't see the underlying structure in most cases.
