Help with wooden waterskis
EHH
I found 2 single water skis at the dump. One is a Cypress garden ski, this one has the front boot and the brackets for the back, it has come apart in 3 pieces, and has termite damage on the back and. The other one has a little termite damage and is still fused together at the front but the 3 sections have come apart at the back. I would like to use these for decorating. Is there an easy way to repair the termite damage and fuse the pieces back together?
Re: Help with wooden waterskis
dump foraging
Jerry Gibbs
I miss foraging at the dump. That is no longer possible where I live and in this day of landfills. Since the skis will be decoration, simple gluing should work. Termite damage might include filling the holes and paint. It is difficult to help without further info/picture.
Re: dump foraging
EHH
Yes, I agree a picture would help. I will try and get one or 2 on this thread later this afternoon. Thank you for the reply!
pictures
John in NM
You'll need either a profile here to post pics or to use a web hosting site for the pics, just fyi. Since this is one of the only forums I know that lets non-members post in general, the question of how to post pics comes up on a regular basis. Having an account on the forum is free and easy so that is what many of us do. The only down side is that there is a size limit on pics, so you will need to be able to resize them.
On the termite damage, if they are to be painted the termite damage will be fairly easy to fix - I like epoxies for filler of this kind, but any filler will probably work fine. I recently discovered that one can thin bondo by adding the polyester resin used for fiberglass work (also sold by bondo). The smell was the tip off :D Once thinned to a self leveling consistency, bondo is pretty handy stuff (it can be dyed with transtint dye too).
Ralph Lipeles
Since there are no structural concerns I would use any wood filler prior to sanding and painting. It would probably be a good idea to use a hair dryer or other heater to make sure that termites are all dead and dried up.
