Lumber drying tidbits
Drying lumber
Below is some information that could be useful to those drying lumber.
1. I am drying some drawer sides and wanted an estimate of the moisture content of the billets I was air drying. A reliable way to determine moisture content is to weigh a test piece, dry it at 220 F in an oven until it stops losing weight, then divide the weight lost by the final weight as illustrated in Picture
1. I say estimate because the test piece I used was cut off the end of the billet, a region that will be lower than the middle, in this case.
2. Some of the green billets had the ends painted with latex paint. It was a partial barrier to moisture loss but not totally effective as evidenced by cracks starting to appear in the billet ends. I recoated these ends with AnchorSeal but to be effective all the cracks that had formed had to be cut away. These cuts generated the test pieces.
3. Picture 2 shows a test piece after a few minutes of drying at 220 F. We can see that the latex paint, which is on the top end, is slowing moisture loss. The bottom edge is drying faster, shrinking more, and curling.
4. As drying proceeds a moisture gradient develops across the thickness of the test piece. The outside is drying and shrinking faster than the inside. As a result cracks begin to appear in the surface to relieve the tension established by the moisture gradient.
5. When thoroughly dry the cracks seal back up and become invisible. Also the curl straightens as the area under the latex paint dries. In an improperly KD board these cracks may reveal themselves at an inconvenient time and place when the lumber is turned into furniture.
Re: Lumber drying tidbits
TomD
What is the signiifcance of the 20% figure, it isn't the percent moisture content, how does having the ratio work for you?
Also, I don't think the cracks seal them selves up, there is no repair happening cracks are cracks. Just a ittle worried about an impication that seemed also to be there in the beech thread.
I have had really good results with Behr superwhite latex, whcih is a paint I have around for various things. It seals ends very effectively, almost as well as the Shell emulsion. And being super white it prottect the ends when they haven't yet made it to shade. The clear emulsion I prefer when I can get it is actually worse than the Behr if sun comes into the picture. And anyone can easily find Behr has it around here.
detailed calculation of moisture content
NHLA reference procedure for moisture content. Oven dry a representative test piece at 220 F until it stops loosing weight to yield the "totally dry weight".
(Wet weight- totally dry weight)/ totally dry weight x 100 equals moisture content of the wet piece. In the case above, the calculation yields a moisture content of about 20%.
Because the test piece was an end it will not be representative of the middle which I estimated to be 20-25%. At this moisture content I can commence more rapid drying.
Keith Newton
Is the Behr superwhite latex a self priming paint? I've not had much luck just using latex paint, nearly as well as using a heavy primer coat.
