Chargeable drill
halinva
if a drill becomes inoperable, is there any way if you can determine whether the drill is at fault if
if the battery (or maybe the charger) is at fault?
Chargeable drill
halinva
Re: Chargeable drill
I take mine to Staley Electric in Richmond VA and they check them out.
Keith Newton
On most of the better brands, the charger will indicate whether the battery is charging, or bad with LED's. Or you might take the drill into a store which sells the same drill, and ask if you can try one of their batteries on your drill.
You might also be able to use a volt meter to check the battery, but you make no mention which drill you are using, so I have no idea how many contact points there are on the battery, so can't help guide you if there are more than two. If there are only two, the meter probes contacting them, should indicate whether the battery is charged or not, if you have it set for DC volts, higher than what the battery will hold.
Ralph Lipeles
A few years ago my Dewalt 12 Volt cordless drill stopped working. I unscrewed the side cover so that I could have access to the internal parts and connections. There was a motor assembly, a switch, some wiring, and a battery assembly. I removed the 2 push on wires that went to the motor and connected them to my voltmeter. With the trigger depressed there was not any voltage across the 2 wires. I then checked the voltage on the batteries. The voltage showed up on the motor, so the batteries were good. . At that point I thought that the problem was in the switch, but the switch wiring was not very accessible for checking things. I then started moving wires one by one with the trigger depressed. I found one wire that, when moved, would start the drill. I squeezed the crimp on fittings on each end of that wire and the drill worked perfectly after that.
You sure didn't provide much information. Brand, voltage, etc? When charging, do the lights on the charger indicate the battery is charging ok? (All of my chargers have a chart on the charger.) Is drill completely dead or very low power and dies after a few seconds? Either way, did it suddenly go bad or gradually? Did it sit for a LONG time since the last successful use?
As mentioned, check with a volt meter, preferably with a digital meter. Most digital meters these days, even the cheap ones, are auto-ranging and auto-polarity so it doesn't matter which lead is connected to a terminal.
Charge the battery. If you have just one charger and the lights on it work as advertised you can assume it is working. If you suspect the charger try find someone with the same brand and test your battery on his charger.
Check between all terminals if more than two. The voltage should be equal to or higher than the rated battery pack voltage. If less, you can suspect the battery pack. If the voltage looks good, the tool is probably at fault.
If the battery pack is dead there are ways that can sometimes revive one. I have had some success with this. Google. Or you may try rebuilding it. Google again. If the battery pack is dead but the tool is good, it is sometimes cheaper to buy a new tool with batteries and charger than it is to just buy new batteries. This is why I had a drawer full of new and unused Dewalt drills until I threw some out.
Brian Roberts
A voltmeter will not give an accurate indication of battery condition since it does not place a load on the battery.
The battery can show proper voltage and still be defective....or unable to put out the proper amperage to be of any use.
A battery tester puts the battery under load while testing.
halinva
Thanks for all of the helpful advise!
I agree with this, but without a way to test the battery under load a voltmeter can usually be used to diagnose whether the problem is in the battery or the motor. (Assuming NiCad battery chemistry) Plug in the battery and try to operate the motor.
If the battery shows full voltage under no load, the motor may still turn over a little even if the battery is bad (or may not). Regardless, this should put a load on the battery. Keep this load on the battery for a bit. Then check the battery again. If it is still at full voltage, I might suspect the motor. If the battery is now at a reduced voltage, I might suspect the battery.
If this test in inconclusive, if unable to test further myself it may be time to get someone else to look at it.
