table construction - wood movement
Gary Kittleson
I am making a table for my son's wedding. The base is from an old sewing machine. The table will be sitting on top of the base, with a drawer below the tabletop. There is only the 4 corner attachment points for the tabletop to be attached to the base - at each corner of the drawer. But the arrangement of the base is such that the screws will have to be vertical - into the top, not the sides.
So, here is my question: I am familiar with wood movement, and attaching table tops to the frame below. In this case, I need to hang the drawer assembly from the top itself. How do I connect the drawer framework to the top without creating movement issues? Since I am fighting gravity instead of working with it, what is different than usual? I'm planning on using quartersawn red oak for the project. Perhaps a slice or two of walnut for accents, but not certain on that yet
Love the idea of making this for him, but just past my comfort zone!
Re: table construction - wood movement
Sliding Dovetail
for the drawer-box sides and the top.
Cut in from the back and leave the male portion an inch short at the front.
Glue in at the back edge.
Drawer box and top will move independently as long as the top's grain runs lengthwise.
Suggestion
I would consider a slightly different design for the drawer and box. You're showing the drawer tight up against the underside of the top. With adequate clearances for the drawer front, this would work, but it is a potential finger pincher. Plus, the 2 5/16" underhang is going to make a lot of the drawer inaccessible unless you rig up some overtravel slides of some sort. If you made a frame at the top of the drawer box, you could screw that into the top to hold up the assembly. Just use single holes at the front and slotted ones at the back to allow the top to expand and contract. Also, you're showing a solid bottom on the box. That isn't necessary unless the idea is to have the drawer slide on it.
I confess, I can't picture what the base of this unit looks like. Is it four legs with aprons around the back and two sides? Does the drawer box unit fit in there tightly, or is there room around it? Either way, you could somehow bridge the space from the drawer box to the surrounding aprons.
Speaking of sewing tables, you could greatly simplify the whole project by using a device favored by the Shakers, who made a lot of sewing stands. They often hung drawers from L- or T-shaped runners screwed to the top.
Ellis Walentine, Host
Mark Hennebury
Orient the grain in the same direction, use either, dowels, biscuits, mortise and tenon, screws and plugs etc.. to join. You can also add a long grain strip above the drawer top as Ellis suggested.
Mark Hennebury
Re: Suggestion
TomD
I have a few of these for machines, and I am guessing this is what we are talking about:
TomD
Mark, I am liking this solution, though if it were me, I would use hardware bonding (super charged doweling) or some tenons cut from the sides, as biscuits will have some minor cross-grain action of their own. I could see the joint failing in 30 years. :)
Aha
Steve jenkins
Personally I don't see the problem with biscuits for this application unless you put a continuous line of them. Every door,both cabinet and entry, made with rails and stiles has cross grain joints in it and in the case of exterior entry doors the bottom rail can be 8" or more wide.
Re: Suggestion
Gary Kittleson
Yes, very similar. I am, unfortunately, stuck at work and unable to reply with new drawings or photos.
That said, Ellis, I am intrigued by your frame suggestion, and like it. Not completely sure how it would go together...I'm assuming something like a 3/4" piece above the drawer...but, not sure how that would change everything. I've not done any sliding dovetails before - I would be open to the challenge and learning, but screws would be much easier for this project. I must confess - I lurk here trying to pick-up what I can, but I'm what you would call a "duffer" in the golfing world. I try, and sometimes hit a nice driver...but the rest of the time, I just need to rely on a set of plans! So, I really appreciate your suggestions.
I absolutely love the Shaker sewing stand idea - but this is a joint gift to my son and future daughter-in-law, and her dad doesn't really go for it!
Tom's photo is just about right on the money. Some differences, but the general idea. That was why I was thinking of enclosing the drawer - as it is open to viewing from the side and bottom. But, perhaps it is not needed...
Gary Kittleson
Redrawn. Ellis, is this along the lines of your suggestion? If I go this route, which I do like, where do I place the screws?
I also turned the plaque 90 degrees, for more stability.
