REAL MILK PAINT
Harvesting drawer sides follow up
Last Occtober my son-in-law was given logs from a huge poplar tree for firewood. I saw an opportunity to obtain some quick free drawer side material. I like to make drawer sides from more or less quartered poplar. The quarter grain minimizes size changes in response to humidity changes. I can make a tighter fitting drawer with quartered material. A tighter fitting drawer that is tight, but not too tight, works smoothly.
After roughing out some billets, two per 26" log section, these billets were end sealed and stored with good air circulation under cover. They are now down to about 25% moisture content, having lost about a third their original weight. Its is time for the next step for a few of them I hope to use soon.
Note, the sawing strategy here is to get a billet more or less quartered with the least amount of effort sawing and splitting. Two saw cuts and one splitting with wedges and I have two billets and two pieces of firewood.
Employing ax, draw knife, chain saw and jointer I get two flat faces on the billets I will prepare for final drying. These two flat faces are critical to be able to keep these heavy pieces under control and against the fence on the band saw.
Finally I saw 2-3" thick slabs from the billets, for quicker drying. These pieces will be moved into the heated area of the house and dried down to about 10% moisture content. I'll finish them off in the oven to get them to about 5-7%, or if it gets hot before I need them I will finish drying in the loft where it gets over 100 degrees on a sunny day.
