Speaking of miter sleds
DizD
I know this goes back a while, but on an earlier thread no one posted a photo of this style. If you need to miter boards over a couple inches wide, this makes it easy. I've used it on boards up to about 8" with good success. The boards have to be cut to exact lengths and the board edges must be parallel because you are rotating the board against the fence.
Re: Speaking of miter sleds
Hank Knight
Nice!
Bart Goldberg
Bart Goldberg
I wonder why you would use a sled versus just tilting your blade?
Bart
Jim Hoeller
Tilting the blade requires replacing the zero clearance with one having a wider throat and getting the blade angle precise can be time consuming.
Bart Goldberg
Bart Goldberg
Interesting perspective. I don't find changing throat plates that time consuming, and setting the blade angle right is not an issue - the scale on my saw works well.
My Tilt Box
has done quite well for a micro adjust on the saw stops and setting the angles in between.
Bart Goldberg
Re: My Tilt Box
Bart Goldberg
I need to get me one of those.
Re: My Tilt Box
It's easy to set the 45 and 90 stops, but it gets dicey when you want 22.5 or 36°. I can set those with a protractor, but the little box is faster, easy to read, and accurate to .05 degree. Close enough for guvamint work.
Re: My Tilt Box
Ron Pemberton
My little Wixley helps me set degrees.
DizD
Old age has something to do with it - have to kneel down to crank the blade over, which is not hard. But then I have to get up again which can be a pita. Then have to do it in reverse a few minutes later. I do various kinds of boxes and this jig simplifies things - pull it off the wall, make the cuts and done. YMMV
William Duffield
If you had a SawStop, you wouldn't need to replace the insert. The zero clearance insert that comes with the saw works for 90°, 45° and everything in between.
The SawStop's trunnion's center of rotation is exactly at the surface of the table, instead of some arbitrary distance below.
