200+ woodworking book reviews
Gluing rare earth magnets
Paul T
Hi all, I am in the process of making a cabinet that needs to have the face frame easily removable. Saw a car show where the interior wood trim was attached with rare earth magnets so that there would be no screws and I thought that's it. Unfortunately the show didn't go into any details. I was thinking a recessed hole and gluing in the magnets flush with the surface. What glue have you used...preferably successfully!
Best Regards,
Paul
Re: Gluing rare earth magnets
John Veerkamp
epoxy
Lee Valley has rare earth
Gary Smyth
magnets and cups to hold them. These are anchored by flat head screws that are countersunk. They also have coin like "receiver" plates that are anchored the same way. Put these in to hold a removable shelf and never had a problem. The nickel diameter size in corners will hold the frame.
TomD
Epoxy works great, rough up the surfaces you are going to glue, but don't overdoo it, they are really just plattings over the magnets which are earth. You might find the rod like ones have more force, and that gluing in matched magnets of whatever size on the frames might be stronger than magnet to metal. Probably some pins to create shear strength and location would help.
If you have a biscuit joiner, you might prefer these:
http://www.leevalley.com/en/Wood/page.aspx?p=43253&cat=3,43715,43717
By the way
Gary Smyth
The magnets are very strong. Once the cup is installed with the screws and the magnet is seated there is no way to pull the magnet unless a more powerful magnet is used to attract the seated one. Forget screwdrivers, or wire, the fit is tight and I think that the attraction is increased by using the cup -- just be aware
Re: By the way
Jerry Nicholson
I use a hacksaw to saw a slot in the side of the cup in case I ever need to remove the magnet. A strong pick should then do the job.
Jerry
Re: By the way
John McGaw
In the early days I took to filing a 'V' groove in the side of the cups before installing them. This allowed me to pull the magnet using a stout surplus dental pick. Lately I've just assumed that the installation was going to be permanent and quit sweating a few dollars that might be saved.
I built a sideboard and wanted invisible "latches" to hold the doors closed. I drilled into the top of the frame on the cabinet and inserted a magnet. Then I drilled into the top rails of the doors and installed a magnet before it was assembled. There is nothing to see. I like it. Be aware that it took considerable planning to get it right. The door magnets are slightly offset and woudl hold the doors a little too far "in", but I installed a stop to make them flush. The various holes have to be carefully planned out and line up after assembly. The holes also had to be nearly all the way through so the magnets would be close to each other. Still very pleased with the result. One more thing. Had to be very careful to keeps the poles right. Get them wrong and they repel each other.
Easy...
John in NM
Stick a block to the magnet with a bit of silicone, or a tiny bit of super glue if in a hurry. It will pull right out of the cup. The silicone will come off easily, super glue won't, but one can soak in acetone to remove it.
I used those cups and washers on one kitchen of my own, only to find the magnets stuck to the little vinyl pads I put between them & the washers (to keep the noise down when closing the cabinet doors) after a day or two of being closed. Magnet came right out of the cup, stuck to the washer.
I still like the method in general, but now I just glue the magnets into the wood and use a washer on the other surface. The epoxy eventually fails but its easy to re-do it.
Re: Easy...
TomD
Though it doesn't probably work in this case, you can install magnets from behind, or glue something over top of them and then they are permanent, but you can still get a good deal of power out of them if you plane the surface down as much as you can.
