ADVERTISE HERE - FREE TRIAL
Speaking of faucets.....
Tim Greif - West of Chicago
I have a shower in a summer home, basically never used that has absolutely no flow. This is an old Delta faucet shown in the pic. I have never owned a Delta plumbing fixture. Fixed lots of Moens, but never one of these. I read where getting that dome nut off behind the plastic handle can cause the entire faucet to break. If that happens, I gotta open up the wall on the other side of the shower to get at it to replace. The water literally just falls out of the shower head pipe. I suspect clogged innards but who knows. The vanity across the room fed from the same supply pipes works fine.
Any tips on these Delta units?
Re: Speaking of faucets.....
An idea
David Yoho
I have all Delta faucets in our house but have not had to work on one like yours. So no help taking it apart. In fact, we're going down this weekend to our summer cottage and I'll be replacing a Moen kitchen faucet with a new Delta.
However, I did have to fix a problem with the shower flow at the cottage recently and although the cause might not be why yours isn't working right, the fix might still work without taking things apart.
Our set up down there is three handles (hot, cold, shower diverter). I pulled the diverter stem out but found nothing wrong. Turned out ,after removing the access panel in the next room, the supply pipe from the valve body to the shower head is galvanized pipe. I knew the inside of the pipe was probably full of corrosion. Not wanting to tear into it at this time, I tried something else.
I removed the shower head and with a pair of channel locks turned the chrome shower head pipe so it pointed upward. Inserted a small funnel and poured in some CLR. Surprisingly it took more than I expected. I waited about 5 minutes, twisted the pipe back to its normal position and turned on the water. All kinds of crud flew out followed by a full stream of water. I flushed the line for some time and put the shower head back on. All's well for now until I get time to replace the galvanized pipe later.
The point is perhaps your valve is restricted with crud from being used lightly and sitting. A little CLR should take care of that if that's the problem. If not, you haven't lost much and will then have to get into the valve body anyway.
Use CLR like penetrating oil
Dick Coers
The day before you start to work on it, start using a paint brush and keep wicking CLR around the thread area of the nut. I actually twisted the whole fixture a little trying to take off the nut when dry. Stopped working on it and started using the CLR for a couple of hours. It took almost no effort after that.
ken combs
I have had that type for years. Never had an issue with them. I did have to put a repair kit in my Dad's about 20 years ago. Just take out the screw holding the handle on and GENTLY work the dome nut loose. Tighten a little, loosen a little if it is corroded in the thread area. Penetrating oil or CLR as another poster suggested may help, but I've never encountered that.
Little more background, I've had 5-6 houses with these that never needed work. I used to move ever 2-4 years though. My Dad's place was built in '67 and I repaired the one needing it years after it was installed. I now live in that house, inherited in '07, and the two bath and one similar kitchen faucet still work flawlessly.
If the shower head itself is clogged, fill a zip lock bag with white vinegar and zip it on the head so that the head is submerged in the liquid. Overnight soak should clear it up.
Now that I think on it, if you can devise a way to cover the faucet in vinegar that would work also if the threads are corroded.
I suspect the age of the faucet may play into the corrosion issue as I think the older ones used a higher quality alloy. No proof, they just look and feel better to the eye/hand.
I agree with all of the above. I have serviced of these units on the houses I flip and at my own house. Generally they require very little work. I have installed the new version of the same faucet on several.
I like the Idea of use CLR as a penetrating agent and will try that. On the older ones I took apart, I did not think of that and used a large par of Channel lock pliers. Carefully engage the teeth in the pliers in the grooves in the dome. Hold the pliers so the teeth fit into the grooves, not at an angle, and gently squeeze and rock back and forth. Try not to squeeze too hard which might increase the threads bite at that location. Also, you can try moving the pliers around the dome and squeezing gently to crack the crud loose and then turn the dome. Watch the body of the valve behind the dome and if you are turning that, STOP.
Locally, Lowe's carries the kits for these and they are very easily repairable. My opinion is Delta is one of the top tier and comparable to Moen. I have much more experience with Delta than Moen, but both are better than the store brand stuff.
PS be sure to turn both the hot and cold off first. Amazing how much water comes out if you don't. btdt
Jim Hoeller
Cheap white vinegar works wonders on your problem. I live with a deep well and mineral deposits are a part of life. Run the vinegar through your coffee maker to clean it and then use the hot vinegar to remove mineral deposits on plumbing fixtures. I don't use hot vinegar on toilets to avoid cracking the china, cold vinegar allowed to sit for a while works.
Thanks guys...
I'll probably use Dick's CLR trick. If that doesn't work, I'll try the vinegar. This place always has answers. :)
