I have a Rikon Model 50-120 sander. Its got a 6 x 48 " belt and a 10" disk. the switch has failed into the ON position. I tried ereplacment parts they don't seem to support Rikon. I tried to call Rikon, but its too early. I will try again in a while.
I can't remember a switch failing in the on position. Welded contact maybe? Any chance I can take it apart and fix it? (I don't know what happened, my son was using it when it failed, and he won't say) I tried blowing it out from the front, but that didn't help.
Anybody know of a source of a proper switch other than Rikon?
Humm, I had the same thing happen to my Delta 12" disk. I purchased a new switch from e-replacments,then took the old switch off,cleaned it (MUCH BUILD UP) and it worked as new. Needless to say the replacement switch arrived the same day. Might try cleaning.
I agree with trying the disassembly and cleaning. If successful you are back up running in a few minutes at no cost; if not, you are where you started and no worse off.
I've repaired many switches over the years this way, most recently on on a jet mini lathe for a friend. Switches used around fine dust seem to be the worst at failing. The switch can easily be stuck in the on position by dust.
Most switches will come apart but some are tricky. They may have screws, snap catches, tabs to bend, or rivets that need to be drilled out. Be careful to note the orientation on pieces and for spring-loaded parts that may fly out. Work at a clean desk - I once spent 15 minutes with a magnet locating a tiny ball bearing in wood shavings in the floor!
Assuming no parts are broken, I clean and re-lubricate pivots and slides with a tiny amount of silicone grease and use a smear if dielectric grease on contacts. If the switch works ok after reassembly, I try to seal it to keep the dust out.
I've also repaired quite a few switches with great success. I think I've only had one fail over the years. Sometimes it takes a little trickery to get them back together so they hole because parts may be broken or damaged when disassembling. But you have nothing to lose other than your time.
