Table Saw Switch Modification Question
Gary Smyth
Reading ChuckInND responses reminds me to ask. Are there pictures of the set up of different saw on/off switch locations? I have a Jet contractor's 10 inch (the old JTS 10). It serves me well. The switch is on the lower left of the cabinet well under the table. Current mount is to the front, and I moved the switch box as far as possible outward but remains mostly inside the cabinet. I am used to it so I know pretty much by stabbing BLIND where it is located even with large sheet goods blocking direct view on the table. I have tried to seal the switch box, but fine sawdust continues to creep in and about every year or so it clogs the contact points so that the saw will not turn on. Seems like it happens at the worst time. Much of the problem is original engineering in that the motor/switch wires are blocked by a combination of motor wire end is sealed in the motor housing, the table top, saw trunnion, and the cabinet, making access hard to reach, the metal cut out is sharp and all existing wire connections are very short.
Next time it happens I'm thinking to make a change. I don't much care what it looks like only that it is convenient and works -- every time. I also want to avoid the possibility of mistakenly hitting the switch.
I'd like to see how others have reduced or eliminated the sawdust problem and making the on/off switch location easier to reach, less likely to clog, and safe. Pictured is existing.
