THE WOODRAT IS BACK!
Contractors Table Saw Motor Quick Disconnect
ChuckInND
I have a 10 inch Delta 34-445X Contractors table saw in my main shop. It has a motor quick disconnect setup. I like it because at the end of the day I remove the motor and push the backside of the saw up against the wall. I also have a 9 inch Rockwell Contractors saw in the small basement shop that does not have the quick disconnect setup. So this week I've been working on giving it a quick disconnect setup. Last night I wired in the electrical quick disconnect which looks the same as what the 10 inch saw has from the factory, and started working on the Delta motor mount pins that I ordered, and need to find a spring for after I modify the pins a little on the spring end. I think that it's strange that it took Delta / Rockwell that long before adding that feature on all their Contractors saws. It would certainly make it easier to move the saw from job site to job site.
Re: Contractors Table Saw Motor Quick Disconnect
Keith Newton
My switch for my old 9" is in a plastic box, which I spring clamp to the top of the leg.
ChuckInND
I installed a paddle switch under the front fence rail. It's a lot easier to find and reach then the original setup that was mounted to the lower part of the cabinet front.
ChuckInND
I guess that I need to keep my ideas to myself. I should know better after all these years in forums.
ChuckInND
If it's not about a cabinet saw, who cares right ?
Chuck, I have a Delta Rockwell 10" table saw that is not a cabinet saw. A contractors saw maybe? Have had it since 1972. Moved it from one house to another about four years after I bought it and then to this house shortly after that. Been sitting in the same spot for 36 years. Obviously moving the saw is not a priority for me. When I read your post my first thought was why would you do that? I had to think for a while and it slowly came to me that if you removed the motor hanging out the back and turned the saw ninety degrees it would sit closer to the wall.
I suppose you could make a rack under the left wing for the motor to hang on and then you would not have to remove the switch. I do like the improved switch, but have never done it to mine. I spent a long time working out dust collection on mine and it works well, if you care. I tested it and its getting over 95% of the dust. My shop is very small and crowded but I only have two tools on wheels. There is just no place for them to go.
ChuckInND
Barry, thank you for the reply. The 9" Rockwell Contractors saw that I have is a 34-607. As I mentioned before, it's in my small basement shop. What I luv about this saw is that it's basically a miniature version of their 10" saws, the physical size of it is about 25% less. You might think that finding 9" blades would be tough, but so far it hasn't been much of a problem. I added the disconnect because I feel that it's a nice feature to have for a Contractors saw. I can scoot the saws backside up against the wall at the end of the day, and if I ever need or want to move it out of the basement it would be that much easier to do without the motor. With shipping the parts were only about $25, about half of that was shipping. You probably already know that as far as dust collection goes that I spent a lot of time figuring out a user friendly and efficient setup for these saws. https://sites.google.com/site/deltacontractorstablesaw/
Brad Chenoweth
Hi Chuck,
I'm intrigued by the motor quick disconnect idea. I have that same paddle switch on my saw, as well. My shop is in the garage, and space is at a premium. How do you attach the removable outfeed table to the back of your saw? I am planning to add a folding outfeed table for my Craftsman contractors saw, but my current design would require a permanently mounted extension table to clear the motor, to allow the additional section to fold down.
Brad Chenoweth
I have a big Powermatic cabinet saw but the saw I use more is a folding contractor saw. If I had to keep just one saw I'd probably keep the portable contractor saw since it is more versatile around the farm. I can take it outside beside the shop and do most of what I need without having to deal with the dust and chips, and there is a whole lot more room. In fact I used it plus a miter saw to build the shop and several out buildings to cut rough oak siding, etc. It's lightweight and not massively sturdy so I usually use a roller stand to catch the long boards. I would like to add a quick cut off switch.
ChuckInND
Brad, the removable outfeed table that I have on the 10" Delta CS that I own was offered by Delta quite a few years ago. Since then I've probably seen only one other person that has one. Why Delta no longer offers them is beyond me. I luv that accessory, and feel very fortunate to have it. It does not interfere with the motor at all, weather it's 90 or 45 degree cuts.
ChuckInND
John, what your describing sounds to me like a newer plastic and aluminum Jobsite saw.
Now I remember seeing that. It looks like you used a "take off" fitting as part of your DC strategy. Your dust hose goes out the rear/outfeed side of the saw. I use the Long Ranger Blast gate with the micro switches on them to turn on the DC, so I wanted the blast gate to be in the front or infeed side near the switch for the saw. I reach down, open the gate turning on the DC and then turn on the saw. When I am finished I turn off the saw and close the gate. Your set up may be better at collecting the dust because it takes advantage of the natural "throw" off the blade. I replaced the little chute (half chute) in my saw with a box that fully encloses the blade under the table. Lots of head scratching, but it works well.
ChuckInND
Barry, if you look closely at the picture of the backside of the saw, you will notice that I also blocked the backside of the blade to prevent the chips from being thrown out by the blade. It moves with the blade, so it works during angle cuts also. And yes, the chute does go with the flow of the dust, and so does the port. good eye. Positioning the port at an angle, also eliminates a bend in the DC hose in order to route it out from under the saw, like what people have to do with the generic plastic table saw dust hood that is still sold today, which is a very poor design that not much thought went into in my opinion.
ChuckInND
Well anyway, in my original post I was not asking for advise. It was a project that I put a lot of thought into like just about all of my projects. I know what I'm doing, and I had already bought the parts for the project as mentioned. I put together what I consider to be a improvement to a machine in a fashion that looks like the saw came that way from the factory. I've been making improvements for woodworking machinery for quite a few years. If my work is always going to be looked at as insignificant by others, with very little to no appreciation for it, then I'm going to lose interest in sharing. Which is about where I'm at now, wore out. I'm to the point that I don't even do much woodworking anymore.
